Old 08-23-2002, 04:21 AM
91civicDXdude's Avatar
Is the MPFI the exact same from d16a2 and d16z6?
is it? i put the MPFI off d16z6 on my car and it is hella big. I've ridden in 4th gen civics with stock MPFI and it doesn't seem as loud.
Old 08-23-2002, 07:27 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
the intake mani isnt exactly the same...it flows better and has a few other differences...shouldnt really make your car loud though?
SOLD!
Old 08-23-2002, 11:20 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i tried to explain to you before...you mix parts and you get troubles. you said you couldn't see how it wouldn't work. well, now you see.
what all did you use so we can figure out what went wrong. i'm pretty sure i know...but tell me what parts you used.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-23-2002, 12:48 PM
what are you talking about ladyinredsi. i never said it didnt work. im saying i used the intake off d16z6 and it sounds way more bad ass than a stock MPFI civic. works great. Im having check engine light come on but its because my EGR valve is screwed
Are all 15x6 steel rims the same from 95-07 ? redroush00 Cavalier 1 04-01-2007 05:24 PM
GM MAFt and venting the type-S. Exact setup and install procedure? Shpyder Engine, Transmission and Drivetrain 14 04-24-2005 05:54 PM
No odemeter or speedometer and trany problems started all at the exact same time sosly76 Cutlass Series 2 10-23-2004 02:40 PM
Is the bottom end the same from evo to 4cly eclipse? 01RSGUDED Eclipse 2000+ 8 05-28-2004 11:22 AM
