Old 08-20-2002, 07:22 PM
sylojai sylojai is offline
Unhappy car died.....please help
hey guys, heres the deal, I just installed CAI and changed the distributor cap and rotor the past sunday. The car worked fine that night and the following morning, but when I tried to start it in the afternoon, it just wouldn't start. The engine sounds like its trying to start but it just doesn't turn over. I don't know whats wrong with it, what do u guys think? Help.......
Old 08-20-2002, 09:25 PM
94civic's Avatar
94civic 94civic is offline
does your car crank over or it doesn't do a thing? if it cranks over but doesn't catch change your plugs and fuel filter if that doesn't work disconnect the big fuel line that goes into the side of the fuel rail and have someone crank the engine if nothing comes out it may be the fuel pump. if gas comes out then something may either be clogged or its another problem. if its not clogged do a spark test by sticking a screwdriver in the spark plug boot (make sure the handle isn't metal or anything else that conducts eletricity) and hold it very close to a ground point and crank the engine there should be a bright blue spark when the engine turns over. if not then you gotta check you ignition system, check your disributor cap, igniton rotor, your ignition coil and other parts of your igniton system. if it doesn't crank over then the only thing i can say is either a dead battery or a bad starter.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
1991 Chevy Lumina is dying!!! Please Help toellej Lumina 1 01-19-2005 04:53 PM
Car keeps dying... Please help. tyler.reiser Grand Prix 2 08-24-2004 06:23 AM
My Golf is dieing please help sbunnell666 Golf 2 02-07-2004 11:02 PM
Battery Dying, please help... alarm causing it?? jackacc '88 - '91 Civic | CRX | Wagon | Shuttlee 23 10-29-2003 10:02 AM
Alternator Dying! Please Help ASAP! blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 18 09-01-2003 06:29 PM
