Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 08-20-2002, 04:52 PM
ImportNut1212 ImportNut1212 is offline
Send a message via AIM to ImportNut1212
Question Brake squeal and question about MCS14 headlights
1.
When i apply my breaks i have a high pitched squeal in the front set, and when i'm just driving ( no brakes applied) i get this wierd kinda metal on metal rubbing noise coming from the rear set. any ideas of what it could be?
2.
what is the difference between USDM MCS14 headlights (97-98) and JDM MCs14 headlights???
i have a 95 240sx and i wanna put an ings body kit on it, but i'm gonna need to convert the front end to MCS14 spec. just wanted to know if there was a difference between the two headlights.
original tofu crew member #06
my car=95 240sx se w/ s14 sr20det
lUcAs-----
Old 08-20-2002, 11:35 PM
TatII TatII is offline
the head lights are dentical to the j spec. and for your brakes. when you brake. does the steering wheel shake? if soo then your rotors are warped and you need to either replace them or take them to a shop and have then cut.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 08-21-2002, 02:03 AM
nah, just squealing and high pitched noise.
lUcAs-----
Old 08-21-2002, 06:49 PM
NISSANSPDR's Avatar
NISSANSPDR NISSANSPDR is offline
Send a message via AIM to NISSANSPDR
Hmm...well I know that if you have carbon metallic brake pads on your brakes...they will squeal b/c it's almost metal on metal...hence the metallic part...but they do help you stopping so it might be that but I doubt unless you know that the pads on there are not as mentioned above.
If they squeal all the time it's time for new pads...cant help you much more...not full mechanic.
Yours truly,
Gabriel
Old 08-21-2002, 07:10 PM
Smfdcatcher Smfdcatcher is offline
Send a message via AIM to Smfdcatcher Send a message via Yahoo to Smfdcatcher
If you DO need new rotors and pads, check out Auto Zone. I replaced both on my 91 240SX about a month ago and got 2 pads and 2 rotors for around 50 bucks. It's not very hard to do yourself and it'll save you about 200 bucks. Just a tip.
Old 08-22-2002, 12:05 AM
Th*GgEd_OuTtTt Th*GgEd_OuTtTt is offline
UMMMMMMMMMM u really need 2 get ur rotors cut... just go 2 n e shop and get them done... for like 5 bucks a piece it's better then buyin' rotors... ... ya and it's gotta b ur rotors... .. mine were doin that and their destroyed... ... oh yea and i gotz metal brake pads and they don't squeel when i drive... well only in the rear they work amazing!!! they lock up before mah front brakes now... until i get mah 300zx calipers... ... does n e one kno wat is needed 2 do a full front upgrade??? and wat brakes would be good for the rear?... and if i could put mah front brakes in da rear... does n e one kno?
Old 08-22-2002, 12:33 AM
NISSANSPDR's Avatar
Your front brakes (if you have a 240SX SE) are the same as your rear's really...10 inch rotors w/crappy calipers.
Check my friend's site for brake upgrades under the link Performance
http://plaza.ufl.edu/briand/index2.htm
He did a Q45 swap and has personally done a 300ZX TT brake swap onto S14 240SX's.
Yours truly,
Gabriel
Old 08-22-2002, 05:34 PM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
I am having squealing problems with my brakes too.
How did you get 240sx rotors at autozone for 50 bucks? and what do you mean "get your rotors cut"?
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
Old 08-22-2002, 08:08 PM
rotors cut mean they just shave off some of the rotor so that it is a flat smooth surface b/c ur dead breaks r prob grindin' up the surface of the rotor...
'90 LS question about replacing headlights with xenons - please help! calvin2376 LS400/LS430/Celsior 1 01-10-2007 10:21 PM
Question about changing headlight bulbs cficare68 Eclipse 2000+ 21 01-09-2006 03:22 PM
Question about auto-headlights/R&D light controller jeverett C/K 0 03-12-2004 07:54 AM
question about sir headlights tbk49 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 02-24-2003 12:38 PM
Need a few parts. And questions about them. 1SlowAccord Accord/TSX/Accord Hybrid 1 01-21-2003 01:00 PM
