Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 08-17-2002, 10:50 AM
Tight Tight is offline
Angry 1984 733 i idle problem
i own a 1984 733i and replaced the cam. Afterwards I have run into an increase in idle after start up. I also replaced the idle valve and control unit, and timing switch. But I still have the problem. The car has a little over 200,000 and i am the only owner. She has never given me any trouble before this. can someone please help.
Old 08-17-2002, 12:55 PM
TranceMind1 TranceMind1 is offline
Send a message via AIM to TranceMind1
hey yo tight i have the exact same car and maybe we can help each other out...do u have AOL,AIM,Yahoo,MSN?....any of those chaten things...reply....
Old 08-17-2002, 02:41 PM
733i
I dont have an im yet but for now we can exchange over the email. I am working on an im but until then this should work. I have been a tech for over 30 years so i am prteety knowledgable about the automobile but sometimes some problems get the best of us. write back.
Old 10-05-2002, 05:32 PM
Crystal-4-Seven Crystal-4-Seven is offline
Send a message via AIM to Crystal-4-Seven
I also own a 1984 733I that is gave me the same exact problem. I had the idle lowered and it works alot better now, but I was told that the fuel injecters needed to be replaced to completly cure her (sylvia). I dont have the money for that curently so it still bugs me on occaission, but than again the brakes were a more important repair! Buyer beware high schoolers dont need to drive 1984 7-series, but it works for me!
Crystal-
*Buyer beware, high schoolers don't need to own 1984 7-series, but it works for me!*
Old 10-07-2002, 06:10 AM
mike-aust mike-aust is offline
Idle Problem
Has any one messed around with the throttle sensor position ?. this will increase/decrease the idle and it dosen't need much movement to do it.
Cheers
Mike
Old 11-01-2002, 08:53 AM
Patrice Patrice is offline
Question I have a Question
Hi.
I have a question. I chose to ask you because you because you are a owner of a 733 i 1984 BMW. That's the same car I have
I am having trouble with my brake line. When I mash the brakes, she want to pull to the left. I don't know what to do. I got new brakes, now I'm having problems again. What am I to do? My uncle bleed the brakes with 3dot brake fluid. Someone told me I had to use transmission fluid. Are they right?
Please respond.
Patrice
Old 12-14-2002, 05:25 PM
Chris's79 Chris's79 is offline
Lightbulb ur brakes
When u say "new brakes" do u mean just the pads? Uneven pressure could be from the master or maybe the caliper is stickin. Although I'm NO expert on BMW's I think that's the same for just about all cars since there's only a handful of parts to a brake system. Hope it helps.
PS!!!! I've never heard ANYONE recomend using anything other then brake fluid except in emergency:alien:
Old 07-22-2004, 05:57 PM
jimsbmw jimsbmw is offline
idle high
I have the same car, and it has the same problem with the high idle.
It idles at about 1000RPM but should be at 700RPM. I have replaced everything. Trying to fix this.
Sensors, ICV, ICM, Motronic ICU, vac lines.
I'll be darned if I can lower the idle down.
Any help would be great.
Old 07-22-2004, 06:44 PM
jeffreyb4me jeffreyb4me is offline
Re: 1984 733 i idle problem
If the 'newbie's' would take a moment to fill out their 'forum profiles' a little more to save time referencing model, year, etc...I might take a moment to comment on some.
Old 07-23-2004, 05:42 PM
" jimsbmw "...do you have a service manual ?
Old 07-29-2004, 12:34 PM
Jeffrey,
Yes I have a Bentley book.
The car is an 84 733i 5 speed imported from Germany.
170,000 miles
Ive been repairing cars for about 12 years now.
This is my first BMW, and its not playing nice.
It Idles perfect at 1000 RPM, But like I said before the books say it should be around 700+- 50 RPM.
The only part I have not replaced is the AFM.
I have tested it and it passed no problem.
Replaced all the sensors for engine temp, New ICV, ICM, Motronic ICU, O2 sensor, Vacuum lines, throttle switch, cold start valve, Cleaned injectors (tested), repalced Rotor, coil, dis. cap.... Had engine running and hosed it down with alot of water to see if it would die or hessitate. Ran fine. Tested all wires for OHM's.
So since all this is replaced and working perfectly why do you think the idle will not drop.
I dont think the timing chain could have jumped a tooth or the engine would run ruff, or the valves would get bent possible.
So this leaves me stumped!
Any help what so ever would be very appreciated.
Jim
Old 07-29-2004, 09:58 PM
Hey Jim.....you've replaced enough parts, now let's see if we can fix it. Look in your manual and see if it's got the proceedure for adjusting the throttle plate to original spec's. DON'T do it yet, but get 'familiar' with it and that lever adjustment. Mark the lever plate around the locking nut [10mm hex]...it's the one under the visible elongated slot on the rear side of the throttle housing. Use a scribe as paint would come off. With the engine off, open the throttle slowly and listen for the light
'click' of the throttle switch.......just opening, 'click'
just about closed again, 'click'..........if you hear nothing try lightly forcing the plate closed and listen. [it could be off too much to hear but when the plates adjusted it will be IMPORTANT to adjust the switch to where I just stated]
With it 'idling', loosen the lock on the lever plate and see if moving it 'closed' brings the idle to spec.
If it does, snug it down and recheck the throttle switch [ it MUST close at idle ] and readjust if necc.
See where we are and post back..............jeff.......
Old 07-29-2004, 10:31 PM
soprano76 soprano76 is offline
Send a message via Yahoo to soprano76
Hey guys, I have a 1981 733i and I'm not sure but sure the intake covers aren't leaving air, remember the car, even though old with 200k miles, it has a high compression ratio. mine has over 250k and runs like a champ. I had an idle problem until I checked for air leaks and BINGO that was teh problem forme,... hopefully it helps. you can also try www.bmwtips.com they seem to really know what's going on. great group of people. good luck...
Old 07-30-2004, 07:34 AM
Jeff,
Thanks for the suggestion. I have previously checked and adjusted the throttle body switch. It is working. If I leave it loose when the car is running and turn it either way the idle does change ( High/Low ).
But never goes under 1000 RPM.
The only other strange thing is it will surge occassionly a tiny bit at idle. Maybe at most 50 RPM higher. Tach barly moves, but I can hear it raise. I figure maybe one of the injectors is leaking.
As you can tell Im not afraid to throw new parts at it. So I may order new injectors for the hell of it.
Just an add on:
If I pinch the air intake line to the ICV with pliers the idle drops right down to 800 RPM. Right where I want it. But it will run rich doing this. So in my mind the ICM is not recieving the right amount of info from some sensor to then send the right amount of current to the ICV to close the valve. All sensors are new, and wires are good. Since everything works off of milli amps it could be the slightest amount of dirt, grease, paint, etc on a ground causing it to register a lower amperage. And in turn the ICM thinks the engine is still cold.
When the engine is cold the RPM is around 1100-1200 RPM. Within 5 Minutes the idle does drop down to 1000 RPM.
Crazy engine....
Thanks
jim
Old 07-30-2004, 07:48 AM
Jeff,
Just thought I would add this in.
I also have removed the AC system out of the car. It didnt work anyways. As well as the auxilery fan on the front of the car that was attached to the AC radiator.
Can't amagine the AC pump produced enough drag to hold the idle where it should be. Just to be sure the AC system wasnt sending false signals to the ICM ( ON SIGNAL ) I pulled the fuse for it.
Out to the garage I go....
Jim
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 10:39 AM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
1984 Riviera Shifting Problem mpetro Riviera 1 04-24-2009 06:25 PM
