Old 08-10-2009, 06:52 AM
williamjbronski williamjbronski is offline
Question Idling Problem
I have a 97 Cavalier with the 2.2L. It doesn't idle right, sometimes I have trouble starting the car as well... driving around it seemed to be ok but when I stop (either with brakes or putting into park) it sounds like missfiring... where do I start? spark plugs, spark plug wire, ignition coil maybe???
Old 08-10-2009, 08:15 AM
rhandwor rhandwor is offline
Re: Idling Problem
Install new plugs and use a DVOM meter and ohm all the wires it should be around 1/2 scale. If no reading or only when wiggling the wire replace with new wires.
Old 08-10-2009, 10:39 AM
Re: Idling Problem
Thanks!
Tags
cavalier , idle , plugs , spark , starting
