Old 07-22-2006, 11:29 AM
bill4brickwork bill4brickwork is offline
aplying decals
i have read the thread about setting decals which seems to work for me.i am currently trying to set some decals on a tamiya castrol mugen honda with great difficulty. the decals seem to be very brittle and crack very easy. is there any other way of softening before applying thanks for any comments
Old 07-22-2006, 12:04 PM
freakray freakray is offline
AF Modelrater
Re: aplying decals
When you place the decals in the water, use warm water, this will often help soften the decals a little more. By warm I don't mean baby bath water warm either, warmer than that.
AF User Guidelines
Old 07-22-2006, 01:00 PM
stevenoble's Avatar
Re: aplying decals
Are they old decals?? If so they can often crack and be brittle due to the age if they have not been stored correctly.I recently built my Hasegawa Lancer Evo rally and the decals split and cracked and simply wouldn't stick well enough even though I used the Microsol and Set solutions.You could try over coating in Microscale Liquid Decal film before application and this may hold them together better and make them a little bit more usable.
Steve Noble
Old 07-24-2006, 02:42 PM
Re: aplying decals
cheers i do not know how old the decals are. i'll try some of the suggestions
Old 07-24-2006, 03:01 PM
Cold_Fire Cold_Fire is offline
Vendor
Re: aplying decals
Try using a lot of warm water on the surface under the place where the decal must be placed. Use soft brushes; take it to its position and then start removing water pushing the decal in all directions very softly with a brush.
Old 07-24-2006, 03:57 PM
Technoman's Avatar
Technoman Technoman is offline
Re: aplying decals
If they are brittle and break easily when being removed from the sheet then Microscale liquid decal solution should be put on them first and allowed to dry before you soak them. This stuff has saved me on many many occasions.
Not so recently completed, I will get another done soon...:
  1. Fiat 131 Rally - ESCI Sponsor
  2. Taisan Starcard 911 GT2
  3. Zexel Skyline R32 GT-R Gr.N
  4. Sierra Cosworth RS500 ANZ
