Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
View Poll Results: Best turbo application
JDM b16a 6 8.70%
b18a 5 7.25%
b18b 26 37.68%
b18c 16 23.19%
JDM b18c spec R 3 4.35%
JDM ZC 0 0%
JDM H22 5 7.25%
B20 8 11.59%
Voters: 69. You may not vote on this poll
Old 08-09-2002, 09:37 AM
QuickSilverEF9 QuickSilverEF9 is offline
Send a message via AIM to QuickSilverEF9
B-series Turbo application
I have gone through many transformations while coming to the decision of my engine swap. Any way I look at it I am going to want to go turbo. At first I was going to buy a ZC with LSD then rebuild the bottom in with forged pistons, rods, rings, gasket and have it resurfaced, have the head and intake manifold ported and polished and have a 3 angle valve job done on the head, then go turbo. Then I found out I can do the b16a swap for $3800 instead of $5200 (what another shop origianlly quoted), so I decided to go b16a and then later on turbo it using the F-max turbo kit. Now I have been told that a b18- series motor would be the best bet for turbo because of the compression and size. A b18a (140hp 118-121 torque) 1.8liters compression? It makes good torque and with required modification to run turbo I could have it past 160hp with ease (head work and bottom end work). Others have suggested a b18c or b20. What would you suggest?
1997 Golf GTI VR6
-Leather Interior
-47000 miles
-JVC KDSH707 Head Unit
ON THE WAY
-2xInfinity Kappa Perfect 6.1 components
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Brock B2 deep dish wheels
-Suspension.....
Old 08-14-2002, 07:43 PM
Tominos Tominos is offline
i say b18b for turbo, low compression and pretty cheap compared to the b18c. although you have to boost more to get the same horsepower, the b18b would be my choice. has more torque too.
Old 08-16-2002, 01:09 PM
delsolsi delsolsi is offline
Definatly go for the B18b. After you build the bottom end and change the cams it will be just as good as the B18c, but much cheaper. I've also heard that you can convert these to vtech by putting on a B16a head.
Old 08-22-2002, 09:59 AM
Jeffbunge Jeffbunge is offline
Send a message via AIM to Jeffbunge
Sleave a B20 and pop a B16 or B18C5 head on it, you've got a bullet proof engine. Plenty of room for boost, and if i'm not mistaken, that could make your car a little bit fast.....maybe
I have a slow integra now, but don't laugh, cuz one day you'll pull up next to me, you'll look up, and i'll be gone.
Will hit 10's
CRVTEC+Large turbo = Wow
www.crvtec.com - great site
Old 08-22-2002, 02:46 PM
Whitey001 Whitey001 is offline
I agree a b18b would probably get u thr results you are looking for
Old 10-29-2002, 08:16 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Re: B-series Turbo application
If by the "required modification" you mean a built bottom and lowered compression for higher boost, you'll probably not experience much of a hp gain just from that, as lowering of compression lowers horsepower considerably....
There's no replacement for displacement...No, not even a turbo.
Old 11-01-2002, 10:33 AM
Boner Boner is offline
I would say b16a. High compression is not a bad thing if you tune your sh1t. How bout a Vortech SC w/aftercooler on a b16a. 277hp 175ft/lbs on 8-9lbs of boost.
Old 12-09-2002, 11:37 AM
dgonzals's Avatar
dgonzals dgonzals is offline
Send a message via AIM to dgonzals Send a message via Yahoo to dgonzals
Ummm
I agree Boner
Blaaaaaaaaaaaah!!!!
Old 11-29-2003, 09:15 AM
TEAM KLR's Avatar
TEAM KLR TEAM KLR is offline
Send a message via AIM to TEAM KLR
The B18B is by far the best engine to turbo for a street application. it is a better block and cost less to sleeve than the B20, the cost of it and the stroke make it a nice street engine. the lack of oil squiters makes it fall behind for a racing app, these can be added. another shortcomming is the lack of a stud girdle, there are companies that offer billett ones, i highly recomend one if you are going to go over the 300 hp mark or spin it past 8000.
Old 12-01-2003, 10:07 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
If he is going to but new rods and pistons etc....it doesnt matter that the B18B engine has lower compression; He is basically going to be able to chose his compression ratio with all the work he is doing. For ease go with the B18A or a stroked B16 (better) and lower your compression to about 8.5:1. I am personally going to stroke my B16A3 to a 2.0L, sleeve it, all new head bolts, comp ratio at 8.5:1, Turbo manifold (equal length), T3/T4 turbo (16 lbs), 3 inch exaust and downpipe, Tial wastegate, Custom mandrel bent tubing, etc.....That is of course when i get out of NTI and get a real job.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 12-02-2003, 12:38 AM
billab2ong billab2ong is offline
I voted for the B18c1..basically on 7-8psi it will put down the same numbers as an ls at 11psi....the engine flows better and all in all is a better engine.
Bang for the buck definitly is the B18a/b.....for around $600 you can get a complete swap and it can give you 275whp if tuned properly. Not to mention if you want more boost you havent spent $1500 extra so you have more cash for pistons, rods, and the vtec head. Ls/Vtec is nice for boost. rev higher, better flow=300whp
Peter Gibbons: I don't like my job and I don't think I'll go anymore.
Joanna: You're just not gonna go?
Peter Gibbons: Yeah.
Joanna: Won't you get fired?
Peter Gibbons: I don't know. But I really don't like it and, uh, I'm not gonna go.
Joanna: So you're gonna quit?
Peter Gibbons: Uh-uh. Not really. I'm just gonna stop going.
Joanna: When did you decide all that?
Peter Gibbons: About an hour ago.
Joanna: So you're going to get another job?
Peter Gibbons: I don't think I'll like another job.
Joanna: Well what are you going to do about money? Bills?
Peter Gibbons: You know I never really liked paying bills, I don't think I'm going to do that either
Old 12-02-2003, 08:14 AM
TEAM KLR's Avatar
we have found that for a street app the ideal compression is 9.5. this allows you to have good power out of boost and it spools the turbo quicker. if it is a straight race car than you can go with a lower comp and crank the boost alittle more. in 10 years of doing this that is the best comp that we have found for a streeted turbo car.
Old 12-02-2003, 01:39 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
the b18a from 92+ is basically the same motor as the 94+ b18b, the only diiference is an increase of 2hp. might as well get the b18b since it probably has less miles and yes this motor has the ideal compression for f/i.
Old 12-03-2003, 06:14 PM
DirtBike1128 DirtBike1128 is offline
Send a message via AIM to DirtBike1128
Re: Re: B-series Turbo application
just outa curiosity, if ur gunna run a 9.5/1 comp ratio, what is the "good power out of boost" going to b...and is it safe for daily street use?
Old 12-03-2003, 06:17 PM
Originally Posted by TEAM KLR
we have found that for a street app the ideal compression is 9.5. this allows you to have good power out of boost...
just outa curiosity, if ur gunna run a 9.5:1 comp ratio, what is the "good power out of boost" going to b (and @ what psi)...and is it safe for daily street use (i just say this cause "street app" might not be meant as daily driver)?
B series turbo manifold? 13secondcivic '71-'87 Civic | CRX 11 04-29-2006 02:17 PM
Compression ? For turbo application Bustamon '88 - '91 Civic | CRX | Wagon | Shuttlee 3 12-07-2003 01:57 AM
Zc turbo applications Civicsiassasin91 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 08-10-2003 11:28 AM
Fuel setup for a turbo application. ZORT Forced Induction 1 09-12-2002 12:21 AM
b-series turbo manifold!? Poweredbyhonda Forced Induction 1 06-29-2002 09:38 AM
