Old 12-06-2003, 08:51 AM
Bustamon's Avatar
Bustamon Bustamon is offline
Compression ? For turbo application
I've recently parked my DX up so I could do some major mods to it. I've decided to convert to manual and go with a turbo charged D16A6. I was just wondering if I should use the D15b2 block and D16 head or just full D16A6 engine? I want to have good compression and in the Hot Rod Magazine article they said something about lowering the Supercharged D16 from 1.6L to 1.54L and had better compression. They are running 27 psi on it currently for over 400hp. So what should I do. I don't want to use a Sohc Vtec head either.
Old 12-06-2003, 10:56 AM
91civicDXdude's Avatar
well it seems like you already have you mind made up on waht you want to do..
use the d16a6 longblock. the 1.5L has a weak bottom end. Hot Rod used a 1.6L DESTROKED for a better rod/stroke ratio. Its also built all to hell.
If you're set on not using the VTEC head, more power to you, leaves more VTEC heads for us
Old 12-06-2003, 03:53 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Unless your really building up the bottom end(new crank and rods). You will want a lower compression ratio. The high the compression the easier it will be for a stock rod to find its way on the out side of your block. like 9.2 to 1 compression on a stock turbo'd or supercharged d16a6. Unless the bottom end is being built up.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 12-07-2003, 01:57 AM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
B2 bottom end is not as good as the A6 bottom end.
Stay at or near stock compression, going up=less forgiving going down=more lag.
VTEC<
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
