Old 08-02-2002, 03:32 PM
bc4g bc4g is offline
brakes wont stop squeaking
my brakes have been squeaking lately i looked at them and the pads are fine. What can be done to correct this problem?
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 08-02-2002, 04:44 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Did you check ALL the pads? Similar thing happened to me, brakes were grinding, so I checked my pads, and they looked fine, but when I pulled off the calipers, the inside pads were down to bare metal...
Old 08-02-2002, 05:45 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
squeaking brake can alos happen as a result of brake dust on the rotor or drum. you should spray the brakes down with brake cleaner and and then drive it and see if it still happen
Old 08-02-2002, 07:56 PM
jc836 jc836 is offline
Another possibility is that the pads were either installed without using anit-squeal/brake quiet compound or that the stuff needs to be redone (rare). Also check that there is a little anti-seize on the backing plate edge; there is a tab area about 3/4" long and the compound goes on the edge.
Squealing is also due to pads that are glazed from improper break-in or over heating.
For your benefit: My tech recommends that Honda pads be beeded in by driving the car at 40mph and stopping smoothly 3 times-each application should be for about 10 seconds and you need to allow for a little cooling. Do this process several addtional times, park the car to allow everything to cool down and then drive gently for 100 miles.
Grandpa toys-Modded suspensions and other tweaks
'89 CRX Si PDA/NASA/SCCA/Steel Cities ITA pocket rocket
'99 Prelude Base SS - A Sweet Song in Motion
'03 Dodge Dakota Club Cab-gonna tow the CRX
Old 08-03-2002, 01:14 AM
thank you for all your help
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 08-03-2002, 01:57 AM
BullShifter's Avatar
you can apply moly coat on the back of the pads the reduce noise, heat, wear
93 Shadow, belts that won't stop squeaking Kurai Shadow 4 04-14-2011 09:06 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
91 Ciera brakes WAAAY too sensitive vbettiga Cutlass Series 2 03-07-2009 01:57 PM
93 Bonne wont stop beeping, brake light sensor on security monitor lit Kate728 Bonneville 6 07-12-2005 11:41 AM
e-brake light, then squeaking riceball Tacoma 3 07-20-2004 12:36 AM
