Go Back   Automotive Forums Car Chat > Dodge > Shadow
Old 11-11-2010, 07:32 PM
Kurai Kurai is offline
93 Shadow, belts that won't stop squeaking
My sister has a 93 Shadow. We can NOT get the belts to stop squeaking. Our mechanic has replaced each one at least once, and several a few different times. At this point the car has the smallest belts he can possible squeeze on--and it is STILL SQUEAKING.
Has anyone else had this problem, or know what to do about it? We're going crazy over it.
Old 11-17-2010, 06:54 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 93 Shadow, belts that won't stop squeaking
have your mechanic check your water pump. Water pump bearings that are worn out can cause a squeal just like loose belts.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 11-17-2010, 12:52 PM
Scrapper Scrapper is offline
AF Premium User
if everything like water pump he's talking about is good? you can get a can of belt dressing to spray on them. a belt can be to tight or to loose and they will squeal also. like i said if it's not water pump or anything making squeal the belt's squeal try the dressing.
Old 04-13-2011, 09:20 PM
bls44 bls44 is offline
are you sure it's from the belts?
not mine, just googled.
My camry ('95 V6) has turned into one of those annoying cars that squeaks whenever it's rolling. This is especially apparent when driving at low speeds. It does this without me touching the brakes at all. It also squeaks when I brake, but it has always done that and that's not nearly as annoying. It may have something to do with the new rear rotor that I just got, after the old one seized up. That's when the constant non-braking squeaking started. I have already taken the car to a mechanic, who says the brakes are working fine and didn't fix the squeak. Anybody know what this is?
Possibly a bad joint, CV most likely in this case. Also, you'll probably want to try either removing the shims on the front brake pads, and either replacing them, or just running with them off for now. I used to have the same annoying squeaking in my 99 that no one could figure out, and I was messing around with the brakes one day, took the shims off and ran the car without them, and the squeak was gone.
Old 04-14-2011, 09:06 AM
AF Premium User
on brakes squeaking it will sqeak if pads are loose or glazed and you can take pads and run sand paper over the brake pads.
Stopped on Hwy and won't start kprellop Rodeo | Passport | MU 6 06-07-2009 01:35 AM
HELP! i have a ticking noise that won't stop 96' Rodeo patriotgrl Rodeo | Passport | MU 10 11-26-2005 12:30 PM
Most desperate member to have a poll about them that they won't stop whining FormulaLT1 COMPLETELY off-topic 22 11-05-2005 05:23 PM
squeaking while driving won't stop rraven Camry/Camry Hybrid/Vista 1 04-23-2004 10:53 PM
