Old 07-30-2002, 03:40 PM
daddys's Avatar
daddys daddys is offline
prelude engine
i was curious about putting a h22 or h23 engine in my 88 4 door sedan,,,i know this swap is highly not recommended,,do you guys know where i would find motor mounts and what exactly i would need to complete the swap,,and about no power steering thats fine but i was wondering about the no a/c,,does that mean no heater or just no cool air a/c?
Old 07-30-2002, 04:15 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
I would assume given that you have all the mounts and its running in your car...no a/c would just mean no compressor. (because of the tight space). Your blower/fan in your car would still be functional. In fact if you have that little button that lights up when you switch your a/c, it will still light up. Your heater should still work too because it works of your radiator.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 07-30-2002, 04:17 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
place racing sells a half ass weld-in kit..that's really the only kit available right now...
SOLD!
Old 07-30-2002, 04:28 PM
daddys's Avatar
would i need a new hood and around how much would the swap cost me if i were to do it myself
Old 07-30-2002, 04:57 PM
EF_LSVtec's Avatar
Yes, you would probably need a new hood...Price for swap, tough to say, but here are the parts that you would need (same as doing any other swap) just find out how much they are and add em up...supply the labor and there you go...
Axles & appropriate half shaft
mounts
shift linkage
distributor
ecu
injectors
rear bracket
injector resistor box
* given that you've wired your car for MPFI and you have a complete motor and tranny w/ starter and matching alternator ( right obd plugs).
* provide for new radiator hoses (upper and lower), timing belt, water pump, oil, cap & rotor, coolant
AF Bay Area Crew
Retired SOLD 1/08
Old 07-30-2002, 05:28 PM
marked001's Avatar
Moderadur
...you shouldnt need a new hood if the engine is mounted correctly...I've seen plenty w/ stock hoods...well, not plenty...but the few I've seen had stock hoods
SOLD!
Old 07-30-2002, 06:17 PM
SkyNex721's Avatar
SkyNex721 SkyNex721 is offline
Send a message via AIM to SkyNex721
I wouldn't recommend Place Racing mounts for anything. That's what I have in my CRX and it vibrates through the 3500 - 4500 band.
R.I.P. - You shall be resurrected.
Old 07-30-2002, 07:41 PM
toontowncivic's Avatar
toontowncivic toontowncivic is offline
I was looking into doing this swap as well and from what I found it is extremely dangerous to do this swap. you have to bang out some parts in the engine compartment which weakens the car plus the engine is a lot taller than most so either you need a new hood or else it is really low to the ground and can rub some very vital parts so in my opinion I wouldn't recomend that engine see if you can find a JDM b18c they run pretty much the same horsepower.
Old 07-30-2002, 09:09 PM
EF_LSVtec's Avatar
B18c is tall too...maybe just a hair lower than an H22 if not the same. Hasport mounts, the better of all available mounts so far (i think), made the billet ones about half an inch taller than the old ones. ONe of the reasons is because of swaps like this and it will give your axles a better angle too. You can change your hood to a ZC or take the webbing off underneath your stock, therefore keeping your hood. I hope your not planning on autocrossing with this motor...
AF Bay Area Crew
Retired SOLD 1/08
Old 07-30-2002, 09:18 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Yep, deffinitely for quarter mile runs only! Handling would be trashed.
Old 07-31-2002, 12:34 AM
daddys's Avatar
the only part about doing the swap that i am worried about is ( you have to bang out some parts in the engine compartment which weakens the car ) weakens the car,,,so what does that mean exactly,,would the engine sag down slowly from a weak engine compartment?
Old 07-31-2002, 01:13 AM
EF_LSVtec's Avatar
First of all, reason why engine compartment needs to be banged is to fit the darn engine. Free pulley space and rear lip for vibrations..only compromise on strength would probably be the crossmember...you may have to cut and hammer it down to fit the header...not all headers, in this case, if you're putting in a jdm 4-1 header. But you can acquire an aftermarket crossmember like from place racing and there would be no more compromise.:sun:
AF Bay Area Crew
Retired SOLD 1/08
Old 09-05-2002, 12:45 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Red face
The only thing you should have to "bang out" is move the Firewall back a little bit, other than that you shouldn't have to move anything else around. Although it's recommended that you take out the A/C, power stearing (that's nutz), and other unnecessary stuff in there. No, you don't need a new hood for your car, the stock one you've got will fit fine. You should be able to find the right mounts on E-bay, but I'm not positive they'll have them (I've only looked at the ones for the 92-95 civics). A new suspension system for your car would be a very good idea also, because if u use the one you've got now most likely your car will have the front way low and the end a little higher up; it's just not ment to hold that much weight. Here's a link about how to do the swap and seemingly everything u need and need to do for it. Hope this helps ya out. Peace...
*Sorry here's the link: http://h22hybrid.20m.com/
Old 09-05-2002, 01:20 AM
daddys's Avatar
where's the link
Old 09-05-2002, 01:52 AM
EF_LSVtec's Avatar
try this link... www.hasport.com
AF Bay Area Crew
Retired SOLD 1/08
Could I take a 1999 Honda Civic Motor and put it into a 1994 honda prelude? jluzzrebellion General Discussion 2 02-10-2011 12:40 AM
WTB: H-series engine parts, P13 Auto ECU, '92-'96 Prelude DS mount CivicSpoon Classifieds 1 05-31-2009 04:58 PM
93 Prelude Engine Swap?? euro boy Prelude 25 04-07-2004 03:43 AM
Prelude Engine Pimpin Yoda Accord/TSX/Accord Hybrid 9 08-01-2002 07:06 PM
Prelude engine Problems jazza12 Prelude 4 03-21-2002 05:16 AM
