Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 07-05-2002, 02:21 AM
euro boy euro boy is offline
Send a message via MSN to euro boy
Angry 93 Prelude Engine Swap??
hey, im new to this forum...
i just have a couple of questions to ask concerning an engine swap..
i have a 93 SR prelude (SI in the USA)...i want to take that engine out....and put another one in...i justttt got a new tranny for that car...so i have to put in an engine that wont require me to change the TRANNY againn..cuz as i said, itz brand new....
i dont want to put in the same SI engine...since i want to see if i can put in the SRV ENGINE....cuz itz got more hp and for other reasons as in the 'vtec'....which i want to have....
are there any other engines that can 'fittt' into the 93 si prelude and that have more then 160 hp(the hp of the CURRENT SI) ....and can the 'vtec' (190hp) fit perfectly into the 93 SI BODY/?????
and what other engines would be better....or more efficient to put in there..without doing majorrrr changes to the car...??
thanx in advance!!!!!
Old 07-08-2002, 06:22 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
Unhappy WHATS UP?
What do you want to do in the future?
Will you keep it standard or boost it?
If you are thinking on boost just spend some money on the original engine and put 12psi down its throat it should be good for 300hp.
if you just want a quick fix then both gen 4 and gen 5 h22a's fit straight in but bye bye to the tranny plus the ecu. By the way who wants an auto anyhow?
I just saw a h22a in a 92 integra it goes well.
all the best :flash:
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
Old 07-09-2002, 01:43 AM
thanxx
hey, thankz a lot man......seriously...
the car is stick...
and ure sure i have to change the entire tranny and ecu?
how much does that usually cost..for the ecu and tranny.....to change it...im guessing a lot
i thought i could just put the engine in, without changing the tranny or ecu, i guess i wuz wrong..
i dont want to do no supercharging..or turbo or whatever...
im gonna do minor performance upgrades.....
gonna do body and interior..and stuff like that.
the h22a is what engines exactly..what year prelude ?
i want the 93 SRV engine inside, and will if i do that, will i have to change the tranny and ecu /??
Old 07-11-2002, 03:09 AM
WHATS UP?
H22a ???????
I dont believe it. If you dont know I can no longer help sorry. :flash:
Old 08-02-2002, 05:23 AM
JDMLUDE93 JDMLUDE93 is offline
Send a message via AIM to JDMLUDE93
H22a
whats up?
I just did the swap from a h23a (same as yours) to the h22a (vtec) in my 93 prelude. The h22a will run you about 2700 shipped and will include a new tranny and ecu. everything you need to make the complete swap. The JDM h22a will fit any 92-96 prelude, and will produce over 200hp ( 40 more than the h23a). I am suposed to get my car back tomorrow or by monday, and will post the news.
Hope i could have been a help
JDMLude93
Old 08-02-2002, 02:22 PM
Cool thankz a lott!!
hey whatz up, thankz a lot man...
u helped a lot...if im still planning on doing that swap....
thatz whatz im gonna do..thank you very much..!
latezz
Old 08-06-2002, 12:56 AM
curveball3110 curveball3110 is offline
I'm sorry, and correct me if I'm wrong, but isn't the H23A the 220hp Type S engine found in 5th gen Preludes in Japan? It's ported and polished, too. That's what makes the extra power over the J-Spec H22A, which is only 200hp. Thanks. Peace
Old 08-06-2002, 09:09 PM
wrong
You stand corrected :flash:
Old 08-15-2002, 05:09 PM
blueluder blueluder is offline
Send a message via AIM to blueluder
The H23A is the motor that comes in the 4th gen prelude Si and it only has 160 and is non-VTEC. The H22A VTEC is the same engine found in the type s in japan it just has differnt cams,pistons,LSD w/atts, valve springs and all the blah blah than the regular J-spec.
Electron blue
Stock 5 speed
greddy evo exhaust
AEM CAI
Wings West Agressore 2 body kit
Greddy shift knob
Old 12-12-2002, 12:10 PM
JDM69 JDM69 is offline
Thumbs up Your options
Listen I'm doing the same thing rite now as we speak. You can do what you want, I'll tell you bout what I'm doing.
JDM H22a type S engine swap, and automatic to manual conversion (I researched and its prefectly fine and easy to do this, just make sure the pedal assembly is done properly). From there the sky is the limit, and make sure not to skimp on the parts when you do it the first time its well worth the wait and the money. if you have more questions feel free to hit me up
Old 12-28-2002, 09:36 AM
ryan45845 ryan45845 is offline
isnt it ture that if you want to go turbo then its best to stay with the h23a based on its lower compression and no Vtec........i was just given a 92 prelude in need of a little body work and new seats.....the engine has 72,000 on it and me and my moms boyfriend are planing on turboing it adding a body kit doin other work and then selling it.......would it be better to get a H22a or stay with the h23a.......we are looking for between 300-325 hp.....that is extremly reliable and we dont want straight line car we want it to retain its handling abilities........let me know
ryan
Old 01-07-2003, 06:52 PM
dominate9 dominate9 is offline
Send a message via AIM to dominate9 Send a message via Yahoo to dominate9
Stay with the H23 is you want to boost. H22s are better for all motor applications due to their highest compression ratio.
97 Accord EX Coupe (H22A)
_____________________________
18" Focal SD5
225/40/18 Kuhmo Ecsta Supra (712)
AEM Cold Air Intake
Walbro 255lph Intank Fuel Pump
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
Katzkin two-tone Leather
3 JL Audio 10W3s
Kenwood DPX-4020 Double Din
Old 01-08-2003, 02:21 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
300 hp @ 12psi? from an h23a? u guys are joking? plz say u are, because there is NO way, simply by putting on a turbo, an running it at 12 psi...sorry guys, not tryin to flame, jus didn't want ppl to be reading false information.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 01-08-2003, 04:08 PM
im not jokin about 300hp but i never said anythin about just turbo charging it.......that is just a starting place.....of corse im doin exhast too along with other things taht we are planning now......and who said 12 psi.....sure most kits run between 8-12 psi but were goin higher then that not sure how much higher because we do know that certain things will need to be replaced in order to work right......pistons ect......we want this car to have everythin that it will need.....were not cutting corners with it........
ryan
Old 01-08-2003, 11:37 PM
ok ok, sounds better then. i jus thought u meant putting the turbo on at 12 psi was gonna put u up to 300hp. thats why i found it pretty tough to believe, but if ur goin about it like u say, then good luck man...keep me updated on ur project.
2003 Infiniti G35
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
possible 89 prelude engine swaps? gi_aos JDM Motor & Parts info/chat 4 02-20-2005 10:42 PM
89 prelude engine swap h22a 89lude Prelude 1 12-09-2003 04:56 PM
Prelude Engine swap help!!! Civic2k2Rider Engineering/ Technical 0 06-19-2003 07:43 PM
