Old 07-22-2002, 08:26 AM
mp3z24's Avatar
mp3z24 mp3z24 is offline
tamiya basic putty help
hey, so i need to know a good way to apply tamiya's basic type putty.
i tried to use it a bit the other day, and the finish was absolutely horrible. i know it wont be perfect, but this surface is terrible.
how should i be applying this stuff?
is there a good technique to make it go on well?
normally i read the directions, but the entire tube is covered in japanense, so all i can read is the name of the product.
damn, i wish i wasnt an uncultured american:silly2:
~mike
CURRENT MODELING PROJECTS....
Tamiya Nissan R390GT (Body & Decals Remian), Fujimi Silvia S15 Autech (Body Paint), Tamiya RX7-R1 (Not much done), Revell New Beetle w/ Street Racer Upgrades (Scratch Building Body Kit), Tamiya Skyline GT-R (Body Paint), Tamiya Escort RS Cosworth Rally (Body Paint & Decals), Tamiya Jaccs Accord (Street Conversion) (Body Paint)
Old 07-22-2002, 10:30 AM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
i dont like the way tamiya basic putty finishes either. but it could be my technique too. this is what i think we should do... get rid of excess putty before it dries so that you will have less to sand off. try not to let little clumps dry up on the model or you'll be sanding forever. use something like a small spatula to apply it and to get rid of excess.
Also, it depends on what you're trying to do with it. if you're trying to smooth your model down, basic putty is good. if you're trying to build fender flares and body kits, you're better off using epozy putty. hope that helps
Old 07-22-2002, 10:40 AM
hirofkd's Avatar
hirofkd hirofkd is offline
No matter what brand of hobby putty you use, it comes down to learning how to use a spatula. Here, I'm showing what I'm using. The top is a conventional spatula, which you can find at any art supply store. My primary tool is the second one, a dull Olfa knife, and this works for both large and small areas. The third one is an Olfa design knife for small application. Hold very small amount, and try to apply putty as thin as possible. Hobby putty like Tamiya one isn't meant for thick application. (no thicker than 1 mm, I say.)
Also, you can thin Tamiya paint with Gunze's Mr. Thinner or compatible thinner. You can apply thinned putty with a brush evenly. While you can control the thickness with custom thinned Tamiya putty, but Gunze's Mr. Surfacer 500 is made just for this type of use.
Hiroaki Fukuda
Old 07-22-2002, 10:51 AM
jaykit21's Avatar
jaykit21 jaykit21 is offline
Banned
Tamiya
Tamiya has some good products, but not everything they make is best out there. I like Squadron's green putty. It doen't pit and hole up like some others and it wet sands like a dream. Try some. For your putty you have now, let it dry more and wet sand GENTLY. Maybe this will work. :bandit:
Old 07-22-2002, 11:06 AM
mp3z24's Avatar
aight... thanks for the help so far...
all i have tried so far is applying putty. i couldnt get the putty to apply right so i havent even got as far as sanding it down... im gonna try to use a spatula as soon as i can get my hands on one... i think that should solve most of the problem. now i just need to practice!
i also might try to look for some options on different putties to try, but i have to check the hobby shop to see what they have...
~mike
Old 07-22-2002, 03:48 PM
daggerlee's Avatar
Also keep in mind that as putty dries it will shrink a little, and you have to be prepared to sand it down
Dan
Stripping tamiya basic putty?? thizishkenny Car Modeling 3 07-24-2004 10:04 PM
applying tamiya basic putty Profoxcg Car Modeling 8 11-11-2003 11:36 PM
Tamiya Basic Putty vs Polyester Putty tc3house Car Modeling 8 11-02-2003 12:38 AM
HELP Tamiya basic putty melted plastic BOOSTD Car Modeling 5 09-18-2003 10:07 PM
how NOT to use Tamiya Basic Putty freakmech Car Modeling 16 07-14-2003 02:55 PM
