Old 09-18-2003, 02:23 AM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
Angry HELP Tamiya basic putty melted plastic
I started some work on my Cefiro and I was filling in some gaps with my Tamiya basic putty. I put a bit to much on an area and thought I would use a toothpick to scrape a bit off. Anyway I started scraping little bits off and then I noticed the plastic coming with it. It nicely melted through part of the body so I scrubbed the area with warm water and sanded it as smooth as possible it's a bit of a mess though. Should I reapply putty to that area? Has anyone ever experienced this before?
Old 09-18-2003, 03:01 AM
flyonthewall's Avatar
Car Mod guy
Re: HELP Tamiya basic putty melted plastic
It will attack the surface of the plastic as thats what i needs to do to bond to it. Should have just left it then sand back when dry and it would have been fine.
Old 09-18-2003, 07:55 PM
Tommy Gunner's Avatar
Tommy Gunner Tommy Gunner is offline
Did you prime the plastic first? I like to paint it a color so I can tell if its going through the paint.
http://photobucket.com/albums/v107/MacsModels/ Pictures of my models
Old 09-18-2003, 08:20 PM
joecwlaw's Avatar
joecwlaw joecwlaw is offline
same thing happened to me. However, the reason flyonthewall said is correct.
Old 09-18-2003, 08:24 PM
Kasso's Avatar
Kasso Kasso is offline
Send a message via AIM to Kasso Send a message via MSN to Kasso Send a message via Yahoo to Kasso
well if if melts the plastic to bond, isnt priming the body defeating the purpose of the putty?
1995 Acura Integra Special Edition (something real special about a 5000 rpm changeover... )
Old 09-18-2003, 10:07 PM
hirofkd's Avatar
hirofkd hirofkd is offline
All putty work should be finished before applying primer, otherwise it defeats the purpose of primer of hiding inperfections and scratches etc.
Basic putty is not suitable for thick application. You an either slowly build up a volume by proceeding layer by layer, or use epoxy or polyester putty.
Hiroaki Fukuda
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
