Old 07-19-2002, 09:28 PM
hotasshonda hotasshonda is offline
Send a message via AIM to hotasshonda
Hooking Up A Tach
Well i got a tach to day since my DX doesn't have one and i was just wondering how to hook it up. I need the negetive side of the distributor to get the rpm's, and a wire that only turns on when the car is in the "ON" position. I need another wire for the light in it also. So if anyone know what i can tap into let me know. Thanks.
Old 07-19-2002, 10:18 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
When I put my monster tach in I used the power line to my head unit. To light it up i used the line i have running to my foglights.
Old 07-19-2002, 10:33 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I attached the tach to the cover over my guage cluster, i ran the wires down inside the dash to the fuse box for power and illum. and the rpm i attached directly to the connector on the back of the cluster that would normaly feed the tach on an si.It's the left side connector like 2nd wire from the left, i think it was a blue wire. Check your haynes manual it should tell you which wire.
hope this helps.....gunnmen01
My other ride..... is YOUR MOM !!!!!!
1999 LeSabre - strange short-term fix for speedometer and tach that sometimes works Taurus1997 LeSabre 8 01-07-2011 01:29 PM
Max AC Clicking/Tach Problem tominton Cavalier Problem Diagnosis 1 07-09-2009 03:27 PM
Please help me hook up my tach csaddict '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 10-08-2002 05:33 AM
Tach hook-up 89CIVICJUNTZ Engineering/ Technical 2 06-30-2002 01:21 PM
Tach Hook-up 89CIVICJUNTZ '88 - '91 Civic | CRX | Wagon | Shuttlee 4 06-29-2002 06:14 AM
