Old 10-06-2002, 06:51 PM
csaddict's Avatar
csaddict csaddict is offline
Question Please help me hook up my tach
I just bought a 96 Civic CX and it didn't have a tach. I went out and bought one and hooked everything up but the wire to the coil. I can't figure out which wire coming out of the Dist. cap is for the coil ground please help me. Does my car have a tach lead inside the car even though it doesn't have a tach? Thanks in advance.
Old 10-06-2002, 07:36 PM
EFsleeper's Avatar
EFsleeper EFsleeper is offline
Send a message via AIM to EFsleeper
usually its the blue wire coming out of your distributor that you use for a tach hookup. At least that what it is on my car.
Stop looking at my Autometer!
Old 10-06-2002, 08:33 PM
csaddict's Avatar
thanks for the help. Is the wire blue or is it blue with stripes?
Old 10-06-2002, 09:35 PM
CustomWhips's Avatar
CustomWhips CustomWhips is offline
Send a message via AIM to CustomWhips
silver dots
well on my civic it was the blue wire with silver dots if yours is stripped probably that one...
it might kinda be in the same location as mine was. its rite behind your h/c gauge its in a big harness tap into the blue and silver one. if you have two the one with silver dots as apposed to a silver strip, is the rpm wire. but from what ive gotten from installing mine was other gauges run off the same wire it just reads the output diffrently..
Old 10-06-2002, 10:02 PM
csaddict's Avatar
Ok with 2 different views on blue or striped or dotted I will get a Diagram. Thanks for the input guys.
Old 10-06-2002, 10:22 PM
its the dotted one man. i promise.
trust me. splice and tap .. dont ground under the fuse box.
the tach crap messed me up to i was rippen shit appart looking for a powertrain control module but it is the blue with silver dots .
Old 10-07-2002, 05:05 AM
csaddict's Avatar
Alright bro I will try it this afternoon.
Old 10-07-2002, 06:26 PM
csaddict's Avatar
I got the tach hooked up it was the blue wire with 2 close silver dots not the blue with single dots, that one is for the srs system. Tach is all set though guys thanks for the help.
Old 10-07-2002, 11:53 PM
æ
aw sorry did you spilce it while you were installing it?
heh if ida seen that extra wire ida went take a closer look at mine..
but o well yuh got it hooked up, good for yuh..
i couldnt think of a good way to mount mine on top my dash but i figured a nice way i started a hole with a drill not far just enough to puncture into the tach then i drilled a holle through the bottom of my dash from above my dash gauges and screwed it into the hole i made in the tach the velcro was temporary and very tacky..
later.
Old 10-08-2002, 05:33 AM
csaddict's Avatar
I mounted mine to the side post with 2 small screws. It sits in the corner of the dash so I can see it really good. I still have enough room to put 2 guage pods when I get a worthy motor in there.
please help! -paint estimate helpme1234 Auto Collision Network 1 06-19-2010 07:11 AM
96 Buick Lesabre Squealing Noise. Please help! I don't know what else to do! Jinisu2 LeSabre 6 05-13-2010 10:53 PM
my 95 pathfinder has 2 problems. Please help MPH/TACH mustangmike1 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 03-17-2009 04:27 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
Please help me hook up ZEX nitrous!! bakabu '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 10-15-2002 07:17 AM
