Old 06-28-2002, 03:57 AM
89CIVICJUNTZ 89CIVICJUNTZ is offline
Tach Hook-up
Does anyone know what wire on the distributor to hook the tach to? I have an 89 Civic h/b ZC DOHC. Thanks.
Old 06-28-2002, 07:22 AM
91zc 91zc is offline
On the plug at the distributor that has two wires going through it. The blue wire is the tach signal.
91 civic 4dr
b16a
14.8@94
Old 06-28-2002, 06:46 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
doesnt that wire go into the gauge cluster, so would it be easier to splice into the wire at the gauge cluster instead from all teh way in the engine bay
Old 06-28-2002, 09:36 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
instrument cluster
I hooked my tach up on the the back of the instrument cluster, it's close to where i mounted the tach and if your car was an si, thats where the factory tach would hook up.
My other ride..... is YOUR MOM !!!!!!
Old 06-29-2002, 06:14 AM
even if your car is a dx it will have that tach wire in the back of gauge cluster because you can swap in a si cluster without having to do anyhthing so the wire is back there cause the tach works on teh si cluster when put in a dx
