Old 07-18-2002, 07:15 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
reverse lights?????
My car used to b AT and now it's Manual the only prob is they didn't connect the reverse lights. there r a bunch of wires next to my shifter that used 2 connect to the old AT shifter. Anybody have any idea which one is the right one to trigger the lights, I'm assuming the others r 4 the indicator lights on the dash.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 07-18-2002, 11:17 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
right underneath the distributor and above your transmission are 2 wires that are supposed to run your back up lights. they are special plugs like male and female, so you cannot interchange em..see if they're connected...if they are not, retrace and see where they lead to...may lead to 2 of the 4 wires you have by your shifter. If they are...in the engine bay (driver side, by the shock tower) is a connector plug...pull it apart and make sure that all wires matches. meaning if you reconnect it, does each wire connect to the other..the back up light I think is the bottom red one by itself. im me if you need more info.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
rear-light warning signal and reverse lights up on brake 1993 Camry LE V6 patmanj20 Camry/Camry Hybrid/Vista 7 07-24-2008 01:01 AM
Reverse lights,alarm lights &signal indicator doesn't work Bigpauly52 7 Series 1 06-08-2005 02:34 AM
'90 Chevy 2500. No reverse lights. Where is Backup light switch? kpwall Engineering/ Technical 0 01-11-2005 07:46 PM
2000 Silverado--Reverse lights/cargo light Ruralmedic Silverado 6 12-30-2004 07:20 PM
no backup lights - reverse light switch? blhfla Golf 2 02-08-2004 01:51 PM
