Old 07-14-2002, 08:08 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
Test Pipe Bad, Good? Help Please!
I was thinking about getting a test pipe for my 1990 Accord. I have a DC Catback system, DC Headers, and a Short Ram intake. Right now I havea Catco "High Flow" Cat but I was thinking about buting a Test Pipe to replace it. Are these worth getting? Am I better off just keeping what I have? I have heard that getting one will reduce Backpressure bigtime, and I have heard that it isnt healthy for your engine to have little or no backpressure. Will adding one hurt my engine? Will it make much or a differance?
Thanks!
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 07-14-2002, 08:13 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
well it wont hurt ur car too badly, it will reduce backpressure which is good for the car anyway, however the car will be alot louder, and if ur town has a noise law there, you may be hassled for it. the catco is a good free flow cat, but obviously no baffles will let the exhuast gas flow easier to get more power.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-14-2002, 08:20 PM
luti luti is offline
Send a message via AIM to luti
Backpressure is both good and bad. I know thats confusing, but bear with me. Backpressure helps at low RPM's to get the exhaust gasses out of the cylnders, but hinders performance at high RPM's. That is why headers and exhausts and catalytics have to be purchased and tuned to your specific needs. If you want a street car you want larger than stock diamaters, and a more free flowing system, but not a completly empty system. You won't be able to make it off the line, your car will feel week at the low end. If you are building a race car cut out the cat, if your racing your always using high RPM's and have nothing to worry about. Also, the lack of a cat will make your car significantly louder and make your car that much worse for the planet (ecologically). Please keep your cat in unless your off to the track.
T3/T04E turbocharged ricer.
Old 07-15-2002, 04:08 AM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
No true, you don't want back pressure at all time. You can find out more about this issue on the first thread of this forum (let's get technical)
Also, the lack of a cat will make.....much worse for the planet"
True, and the cat will not make that much of restriction for your street car anyway, so please spare the air.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 07-15-2002, 08:56 AM
spotovi spotovi is offline
Unless your racing keep the Cat. You have a high flow anyway. If you need to prove the difference then race a 1/4 mile with and without. You'll see the difference is almost in your head. If you want to drive around worry free keep the High flow Cat, you already made a good choice. If you want bragging rights and a very loud car then go with the test pipe.
Regards,
Spotovi
97 Integra, 10th Anniversary Addition.
(RS with Non-Leather GSR interior)
B18B
K&N CIA
Custom Bent SS Cat-Back w/SS Dragon Style Muffler (4.5 Inch tip).
Stock Suspension
Stock 14" wheels
Goodyear Eagle HP
Stock Brakes
Old 07-15-2002, 09:00 AM
CivicRacerX's Avatar
CivicRacerX CivicRacerX is offline
Send a message via AIM to CivicRacerX
Putting a test pipe on your Accord isn't going to make a noticeable difference, other than being really loud. If you have a high-flow cat and the DC Sports full exhaust, you're just wasting your money with a test pipe. Odds are you'll buy it and be pissed when you have no low end in your already torque-impaired Honda motor. Seriously, test pipes are for higher output engines that are truly restricted when using a legal exhaust. It's not worth it on your current setup.
96 Honda Civic Daily - H22 Swap
82 Renault R5 Weekend Runner - Nearly Stock
83 Renault R5 Track Car - 13:1 CR, Archer Cams
99 DX header + test pipe sentoyang '96-'00 Civic 1 10-26-2009 03:34 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 04:27 PM
AOD tranny replacement gone not good, Help Please!!!I have an 88 bronco 4x4 with a 30 bigmatt00 Bronco 4 03-09-2005 08:09 PM
bad problems..HELP PLEASE! 4thgen91hatch '88 - '91 Civic | CRX | Wagon | Shuttlee 1 10-14-2003 09:52 PM
