Old 10-14-2003, 09:49 PM
4thgen91hatch 4thgen91hatch is offline
Send a message via AIM to 4thgen91hatch
bad problems..HELP PLEASE!
OK ...i have a std shell with a DX engine (D15b2) the engine has 63,xxx miles on it..the body 210,000. Heres the story. I have 2 1/4 STRAIGHT pipe no cat or res. I recently installed a 4-2-1 header. It ran fine. wanted a deeper sound so i put a glasspack in..(forgot to mention about a month ago i changed from a pm9 STD ecu to PM5 DX ecu, made fore the engine, and it use to have a miss from idle when i hit the gas and fuel cut at 6400, but the pm5 made it all fine and cut off was about 6800-6900) Everything ran fine and then i put that glasspack in. Ran perfect and alot quiter. Then i advanced my dist. Not much, and no pinging or knocking. I then decided I would advance it some more. now until 3000 it misses. I have adjusted to the same pos. it was at.. many times adjusting it, and it will either miss or backfire.. I put it back EXactely where it was form the washer marks and marks i had made and it backfires.. when i put the glasspack in it started to smoke a lil bit.. well were trying to fix it and we noticed the plugs r BLACK as sut..Literally... The car has aq gas smell to it..We think it is running rich, or not getting enough air. Put a new cap and rotor on the dizzy.. COuld someone please help?
Old 10-14-2003, 09:52 PM
I forgot to add that it ran fine after i adjusted it the first time(the first day) then a day later is when i advanced it somemore jus for the hell of it and it ran like shit now.
96' accord bad bad problems help!!! GMAN2.0 Accord/TSX/Accord Hybrid 0 09-10-2005 04:43 AM
talon has bad problems help talonspaz420 Off-Topic 11 01-25-2004 09:01 AM
Test Pipe Bad, Good? Help Please! thewoahna Engineering/ Technical 5 07-15-2002 09:00 AM
Hey Guys - I figured it out - new problem- help please ricodemus '88 - '91 Civic | CRX | Wagon | Shuttlee 6 05-28-2002 03:22 PM
