Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-07-2002, 02:51 AM
imports_only1 imports_only1 is offline
Angry '98 Max with Engine Timing Chain noise...Help!!!
Any body out there with a 97+ Max with an engine timing chain whine? .....happens when the car is parked. my 98 maxima SE is whining like crazy. any ideas on how to fix this and how much would something like this cost? thanks...
Old 03-29-2004, 08:05 AM
robb1138 robb1138 is offline
Send a message via ICQ to robb1138
Question Noisy T/chain
I have the same problem with my 98 Maxima as well...I was wondering if there's a "campaign" out there from Nissan(Canada) for a fix to this problem.I've also been told that replacing the chain is a big & expensive job...Any advice would be appreciated
Robby
Old 03-29-2004, 10:03 AM
I'm not sure how to decode the VIN number listed in this TSB...whether mine was built before or after it, but this might be what we are looking for?
Make : NISSAN Model : MAXIMA Year : 1998
Service Bulletin Num : NTB00054 Date of Bulletin: JUN 19, 2000
NHTSA Item Number: 613977
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
VEHICLES BUILT BEFORE JN1CA31D1YT746029 MAY EXHIBIT A ENGINE TIMING CHAIN NOISE. *TT
Old 03-29-2004, 10:30 AM
what the dealer just told me....
I just went over to my Dealer (Scarboro Nissan) in Toronto here and he told me that there were NO recalls/bulletins for my 98 and he's been there for 8 years...I found it VERY hard to believe since the new 2004 Used car guide states that 97 & 98 Maximas had T/chain guides & tensioner repairs...I will have to call the head office to get it straightened out I guess ...thanx for the info though
Robby
Old 03-29-2004, 01:45 PM
wunfstmax wunfstmax is offline
Re: '98 Max with Engine Timing Chain noise...Help!!!
yeah its very expensive....the nissan dealership i took my max to told me around 3700...i found a shop that dealt only with nissan to do it for 500, and i havent had a that noise since i got it done in october
Old 03-29-2004, 03:06 PM
ogparjay ogparjay is offline
I had the same problem with my 97 max but I had a warranty on it so it was free, luckily.
Old 03-30-2004, 12:48 AM
Re: Re: '98 Max with Engine Timing Chain noise...Help!!!
Hmmm....Can u tell me where u had that $500 repair done?
Old 03-30-2004, 10:21 AM
If indeed it is my timing chain that is making the noise, do I just take it to a Nissan dealer and they'll fix/replace whatever is needed for free? Or is there a charge for this? How long do those TSB remain effective anyways? Thanks.
Old 04-01-2004, 08:05 PM
its called alternate nissan repair in colorado
Old 04-01-2004, 10:52 PM
Unhappy Re: Re: '98 Max with Engine Timing Chain noise...Help!!!
DOH!!!! ...I live in Toronto, Canada....Do u know what they did exactly???....maybe I can find a shop here that can do the same repair....The dealer here wants to remove the engine and replace the timing belt....its like 20 hours work and alot of $$$ so a want a cheaper & effective alternative....let me know..thanx;-)
Rob
Old 05-01-2004, 09:26 AM
mishmosh mishmosh is offline
You just have to replace the timing chain tensioner and maybe the guide. I think they are some $40 each or so. You can actually do this yourself but it isn't easy just because there isn't a whole lot of room there.
Old 05-01-2004, 09:37 AM
Funny thing is that a couple of weekends ago I re-adjusted my alternator belt because it was very noisey especially when I would first start the car.I replaced the belt 6 months ago & I knew I would have to re-adjust it after it had stretched abit...Anywho...once I did that then the "timing chain" noise went away.I was TOTALLY fooled because the loose belt also sounded like a loose/rattling chain.I guess the loose belt also rattled the belt tensioner.
So now the car sounds nice & quiet
2.4 L engine timing chain noise coolsunfire General Discussions 19 02-22-2016 12:59 PM
timing chain noise! phatmattj Cavalier Problem Diagnosis 7 03-28-2005 03:11 PM
96 2.2l Timing Chain Noise marb General Discussions 0 02-27-2005 01:22 AM
dakota timing chain noise jkdon Dakota 2 06-10-2004 07:24 PM
95 200 Sx W/1.6l Engine: Timing Chain Noise?? 65VETTE 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 03-04-2004 08:45 PM
