Go Back   Automotive Forums Car Chat > Toyota > Supra > General
General Discuss anything having to do with Toyota Supra here.
Old 07-04-2002, 06:07 PM
trbomnky trbomnky is offline
Send a message via AIM to trbomnky
Question shimmed wastegate
hey, i have heard about shimming the wastegate on an 87 turbo. i was wondering if it safe? also how much power can you expect from it? also, what mods will take me to 300 hp?:sun:
Old 07-11-2002, 01:48 AM
89Cherokee 89Cherokee is offline
Send a message via Yahoo to 89Cherokee
I dont know much about the shimmed wastegate, but i am currently purchasing an 87 turbo. Here are the mods that I recommed:K&N FIPK, GReddy cat-back exhaust, a boost controller, downpipe and test pipe(illegal). that should get you to about 300hp. If you add a lightweight flywheel and lightweight pulleys it will free up some horsepower and rev faster, but you could shorten the life of your engine by replacing the stock underpulley. Also you can have a turbo upgrade done on the CT-26 which will add about 45hp. But before you do that you should get the Lexus AFM mod, a fuel regulator, and 550cc injectors. After that there isnt too much left. Intercooler upgrade and maybe some little things that would just make it run better and last longer. You realize that if you do all this you will ahve to upgrade your clutch system and you should get a metal head gasket. If your super serious check out a lightweight driveshaft. That's all that I know about the MkIII Turbo. Someone else may feel free to add anything.
Old 07-11-2002, 03:18 PM
Lightbulb
okay, wait, if i just ordered a high flow cat, is that in place of the test pipe? would the down pipe be up higher on the exhaust toward the turbo? confused about that.
Old 07-11-2002, 06:45 PM
On the MkIII supra there are two cats. The downpipe is to replace the precat that is just below the turbo (i think) and the testpipe replaces the second cat, just before the muffler.
Old 07-12-2002, 07:22 PM
Beef Beef is offline
A good place to find answers to all of your tech questions is @ Best Supra site out there
Beef
1986.5 NA MKIII (A/B/A/B/.8)
  • Custom Hard Pipe Intake w/ Cone Filter
  • H4 Conversion
  • TEMS Mod
  • Beef's Fog Light Mod
  • SOGI Short Shift Mod
  • Intrax Springs
  • Illumina IIs
  • NGK Wires w/ Bosch +4s
Email - [email protected]
1973 240Z (Awaiting 2.8T & 5spd)
1982 Toy 4X4 (200k & still running)
1986 Turbo Toy 4x4 (Rare)
1991 Toy 2x4 (Project Turbo Toy looking for 22RE)
If anyone is interested in :
  • 1986.5 MKIII NA (No Title)
    1985 Prelude (No Tiltle)
    1992 Celica (Front End Damage)
Let me know I will sell them CHEAP
Old 08-25-2002, 08:02 AM
88sedan_civic 88sedan_civic is offline
Send a message via ICQ to 88sedan_civic
shimming your wastegate would be safe, just don't put too much washers on, like two on each side. SOGI should have the info. That would boost you up a little from stock boost to 10psi. Impresive huh.
90' Toyota Supra Turbo
Mods:SP63 Turbo kit .68A/R Qtrim. HKS GT 60mm wastegate, JE pistons,Crower rods,Ferrea valves,port&polish head,AEM camgears,Webcams camshafts,HKS 1.2 MHG,MKIV TT intake manifold, Hybrid Intercooler, HKS carbon titanium exhaust system, 3'' custom downpipe, RC720cc injectors,HKS EVC IV,PHR ecu,Blitz ssbov,Chevy TH400 3spd tranny,Hurst shifter,Bosch 1000hp fuelpump,Cartech Fuel Pressure Regulator,Unorthodox Racing pulleys,HKS twin ignition system,custom driveshaft, and a K&N
stage 2 wastegate or kinetic wastegate blksrt4_2005 SRT4 14 03-26-2011 02:04 AM
1990 cavilier to shim or not to shim exalteduser Cavalier Problem Diagnosis 3 08-24-2009 09:56 PM
Internal Wastegate to External wastegate fiberglasscivic N2O | Turbo | Superchargers 13 06-22-2006 01:34 AM
T3 w int. wastegate on manifold w ext. wastegate outlet? wickedboost N2O | Turbo | Superchargers 5 01-09-2005 03:30 PM
Can u turn a T3 non wastegate to internal wastegate Lac-O-Power '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 03-10-2004 03:58 PM
