Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-25-2002, 07:33 PM
dpfloppy dpfloppy is offline
Question Amp Question?
I'm trying to enhance my sound quality in my max by installing new speakers and an amp. Where is the best location for a 200 watt amp though? Will it fit under the front seats or should it just be placed in the trunk? suggestions...
Old 06-25-2002, 07:38 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
ya could prob get one to fit under the seats but ya should prob put it in the trunk
Old 06-25-2002, 07:41 PM
Do you think that there would be a heat problem under the seats?
Old 06-26-2002, 12:36 AM
during the summer if ur car is outside most of the time its gonna be hot either way, im not sure bout when it cools off, it jus depends on how much power ur tryin to get out of it-
Old 06-26-2002, 03:13 PM
OaT97Se OaT97Se is offline
Send a message via AIM to OaT97Se
Im just a lil curious are u gonna run a sub of a 200w amp? if you are thinking about doing that you should think about gettin a high wattage amp maybe 600w at least.. the amp will never push out the max 200w so you will be cut down to about 70w x 2 depending on how many ohms, it could actually go lower.. if anything you should use that amp to juss amplify your interiors.. just my 2 cents..
Payce OaT
Old 06-26-2002, 03:34 PM
I'm actually going to use the amp to power just the speakers. I bought some infinity kappa's to put in. Components in the front and 2-ways in the back. the sub isn't in the plan quite yet.
Old 06-26-2002, 04:00 PM
Decked2DaMax Decked2DaMax is offline
Send a message via AIM to Decked2DaMax
Cool If you want it done right do this......
It depends on what kinda amp it is for me to say its safe under the seat. If i t was me i would not even think bout putting an amp under the seat. Best place for amps is always the trunk. Don;t try to be fancy with amps just mout it to anything in the trunk even to the box of the subs or if u r using fiberglass its different. What i like to do in Maximas is mount it to the left or right side of the trunks with the karpet in the trunks and if its a black or silver amp it will look good. Just mouth it and poke a hole to the left or right and run the wire behind the panels very easy mouting and running wires max 30 min maybe. Good Luck
Sony Xplod Amp question??? Ultimateone Car Audio 18 02-18-2005 02:33 PM
sub and amp question XxslayerxX Car Audio 1 03-19-2003 02:31 PM
Amp question , Do or Dont chris26969 Car Audio 3 11-26-2002 08:08 AM
amp question 11 sec. mr2 Car Audio 0 06-21-2002 07:31 PM
Amp question NeoFreek Car Audio 4 05-09-2002 06:18 AM
