Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-14-2002, 10:41 PM
Civic98 Civic98 is offline
Send a message via AIM to Civic98
is NOS safe??
i was thinking bout getting a NOS in my car ? Is it safe i have a 98 Civic DX ??? becus i heard it can blow up my engine? just wanted to make sure is it safe or not??
Old 06-14-2002, 10:54 PM
MD99SiR's Avatar
MD99SiR MD99SiR is offline
Send a message via AIM to MD99SiR
There are millions of reports and questions just like this out there. The main answer to this question is, if it is installed correctly by a technician then it will not blow your engine that way. And if you use it properly and conservatively then it will not blow your engine. If you abuse the nitrous and try launching with it when you don't know how or using it at the wrong points you can blow your engine. Also if you use too high of a shop for your engine then it could blow your engine. To be on the safe side start out small and use that for a few runs and then work your way up and use it conservatively. If you want to run a higher shot then you might want to invest some money into your engine internals. Do a search under this board and you will find this question answered many time. Hope this helps.
99 Civic SiR
Greddy EVO
AEM CAI
Sportline Springs
17" Enkei RS7 rims in Bronze
Nitto Neo Gen 205/40/17 tires
Red Carbon Fiber Hood
NX kit 35 shot for now, going to up it to a 50
Sparco Black/Red Torrino Racing Seat
20% Window and sunroof tint
Old 06-15-2002, 01:25 AM
znatural1 znatural1 is offline
Nitrous is safe as long as safeguards are followed. Read everything possible before installation. A properly installed kit will give no problems, just be safe when tuning.
Old 06-17-2002, 03:17 PM
blackbob's Avatar
blackbob blackbob is offline
Send a message via ICQ to blackbob Send a message via AIM to blackbob Send a message via MSN to blackbob Send a message via Yahoo to blackbob
Age old question !
As you can see the answer to your question is yes
RogueRacing
"Dare to be different"
SHIFT_imagination
Old 06-21-2002, 06:11 PM
crazy151drinker crazy151drinker is offline
Just dont get greedy with the N2O!! It is way to easy to switch the jets! I little more a little more *BOOM!*
Just realize that a safe max for such a small moter is probably 50hp.
Make sure your fuel system is working well. Things go boom when the motor leans out (or you get a N2O back fire!)
Make sure your N2O is not on when you start the car
N20 is safe! Just dont use it like an idiot and you'll be ok.
Old 06-24-2002, 07:03 PM
boosted331 boosted331 is offline
Just make sure you have a stout enough motor to take the gas. I'm spraying a 100 shot on top of 12 pounds of boost, and it's a kick in the pants 10 LB bottles run out rather quickly when you're cruising around, however
Old 06-26-2002, 03:31 AM
dudewheresmycar dudewheresmycar is offline
Send a message via AIM to dudewheresmycar
this is what you should do:
1. buy the most balls out nitrous you can find and get it hooked up to your car (150 hp shot or more).
2. find the most balls out fast car on the road (something with a v8 or something that seems and looks fast).
3. rev up on the person .
4. push the nitrous switch and blow your engine
5. hope that you beat the car before your car explodes. it'd all be worth it if you won.
hope that helps you out..
"If you drive a car with balls, drive balls out. Or give ME your car."--Me
--I put on altezza lights and gained 25 horsepower
2005 E-150 transient fail-safe no-start joey9940 Club Wagon 1 09-21-2009 09:52 PM
IS NOS safe for my almost stock ls1 horsebro Engine and Transmission 4 12-16-2006 06:36 PM
Cheater NOS ??? Safe? Jed_Atreides Forced Induction 16 06-23-2004 11:29 AM
how much nos can safely be used on my civic? Lxcivic4u '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 25 04-08-2003 08:10 PM
