Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Dirt Bikes
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-29-2005, 07:31 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Honda cr250; online manual, crack in case, and water in bottom end
I just received a loaner 84 cr250 for me to ride. It was not running for reasons of a bad head gasket... which I found out was just the start of the problems. The head gasket leaked so badly that all of the coolant was either in the exhaust, the cylinder, or the crankcase. I repeat... ALL of it Fun project anyway.
The bores look good, as does the piston and rings, but the bottom end has been soaking in water for a few months now. Should I just dry it out, bathe it in oil for a while and run it anyway? Or should I pull it out and rebuild?
The gearbox has a slight crack right around the drain plug. Should I have my buddy TIG weld it while its out, or will that harm the case worse than it is?
Is there an online PDF manual for this bike that anyone knows of?
Thanks
Dragging people kicking and screaming into the enlightenment.
Old 10-29-2008, 10:31 PM
tony36 tony36 is offline
Send a message via MSN to tony36
Re: Honda cr250; online manual, crack in case, and water in bottom end
do not try to use the bearings that were exposed to coolant. It is very hard on them and you will have to do a rebuild very soon if you use them. I would do a fresh rebuild the right way, will save alot of money in the long run.
Old 10-30-2008, 08:54 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Thanks for contributing to AF but this is a very old thread. Therefore, it has been closed. See link below for guidance.
Old Thread Guidelines
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
