Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-06-2002, 01:40 PM
speed-d3mon speed-d3mon is offline
18" on Accord but what offset?
gonna be buying rims here soon. i decided on 18". but what is the correct offset to get. the choices are : 18x7.5 offset+43 or 18x8 offset +45. i plan to lower the car about an inch and i don't want to have the tires rubbing on the fender.
Old 06-06-2002, 01:54 PM
Luke@tirerack Luke@tirerack is offline
more vehicle info first ....
year
model of Accord
sedan or coupe
4 or 6 cylinder
is it lowered
and anything else you can think of that would effect wheel fitment
Luke Pavlick
Objects in the mirror appear ... to be losing !!!
Old 06-06-2002, 02:50 PM
its a 4dr 4 cycl. not lowered yet,but when i do lower the car, it will only be about 1.5 inches. also what size tire do you recommend?
Old 06-11-2002, 11:59 AM
WHAT YEAR IS THE ACCORD !!!!
you need to supply all of the vehicle info if you want a correct recommendation. As you know the Accord is very different for the original 1990 model to the current 2002 models
Luke Pavlick
Old 06-12-2002, 11:45 AM
ooopppps! its a 98 4 dr 4 cyl.
Old 06-17-2002, 08:36 AM
I would suggest an 18x7 wheel with an offset between 35mm and 45mm. You may want to go with the higher offset since you are going to lower the car in the future and the higher offset will be less likely to cause you problems with rubbing
Luke Pavlick
1What does it mean when a 1993 Honda Accord needs an service tune up? tools951 Accord/TSX/Accord Hybrid 1 02-12-2011 01:06 PM
does anyone know what offset means in terms of mufflers ford460bigblock Performance 3 05-08-2005 11:37 PM
what offsets should i use?? chixSI Wheels/Tires/Suspension 13 06-21-2004 01:12 PM
what offset for 17x8 wheels on 95 SE? 95_SX_SE 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 8 04-04-2003 09:59 PM
What offset is needed? 99TrackerConv Tires and Wheels 1 07-01-2002 09:01 AM
