Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 02-08-2004, 12:32 PM
chixSI's Avatar
chixSI chixSI is offline
Send a message via AIM to chixSI
Question what offsets should i use??
I drive a '99 honda civic SI and i'm looking to get the SSR Competition rims and i'm deciding on either 16" or 17" rims. Can someone list me the pros and cons on 16" and 17" so i can make my decision.
Also i'd like to know what offsets i should use for the front and rear to have the rims fit flush!
chixSI a.k.a *jennie*
***Never Drive Faster Then Your Guardian Angel can Fly!!!***
www.teckademicseast.com
www.teckademics.com
www.dtmpower.net
www.motivonline.com
www.importvelocity.org
: TURBO is now in...
Old 02-08-2004, 12:42 PM
unusualcivic's Avatar
unusualcivic unusualcivic is offline
Send a message via AIM to unusualcivic
Re: what offsets should i use??
get 16"s for a civic, they lack the extraodrinary blingerness of the 17's but they'll give you better grip and less rotational mass.
84 Civic 1500S
engine- T3 D16a1 with built bottom end in the works
interior- MOMO seats, Sunpro guages, RCI 4-point harness,
sound system- clarion DXZ825, RF Fanatic P's RF 351S, 1 Eclipse SW6123DVC (currently saving for another)
exterior- satin black in progress
Old 02-08-2004, 12:48 PM
BullShifter's Avatar
Re: Re: what offsets should i use??
Yes, go with 16's. 17's are usually too heavy for civic's & the tire sidewall is too thin. Thin sidewall = poor ride & bent rims!
What do you mean by flush?
www.tirerack.com
www.whalentire.com
Old 02-08-2004, 03:00 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Typically wheels like that come in only one specific offset size per wheel size. Like my 15x6.5 size Rotas ("15) come with an offset of +38 That's pretty standard for "15's "16's are usually +40 +42 offset size. Only when you start getting into deepdish type wheels (they have a wide lip to them) will you see offsets like +4 or some rediculously small number. Also if it's a real wide wheel like a 9J or 10.
For you wheels, make sure they are no wider than 7J if you go "17 or 7.5 width if you go "16 as you can't stick any wider than 215 width tires on Civics, and even then you may have some minor inner fender tire rub. If the wheels you get don't happen to be as flush as you'd like, your option there is getting wheel spacers. They came in various sizes. If you get wide enough spacers, you may need to replace your hub wheel studs with longer ones so that the lug nut will be able to be tightened on correctly. Hope that helps you out some Jennie.
EDIT: Ok I just looked up specs on the SSR Comps... Here's what to get depeding on the size you decide to go with: "16's get the 16x7 and if you go "17 then 17x7.5 size. Personally esp. on your Si, I'd go with the "16's. Yes lighter for one, but I like the look of "16 wheels like the Comps better than if "17 Also of note, I dunno how well the wider width of the "17's would be on tire/fender rub, and if you'd be able to full lock turn your steering wheel being they are wider AND bigger round. What colors do you have in mind? I'd go with the black or gunmetal with a polished lip. Eitherway, if you get Comps I'll be jealous as those are wheels I wanted to get, except they are outta my budget right now.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 02-08-2004, 03:03 PM
Cali Guy
Re: Re: Re: what offsets should i use??
www.tirerack.com
www.whalentire.com
Just an FYI, SSR comp wheels are fairly light no metter the weight, I believe they are 13lbs. in "17 form. I could be wrong though.... :o
As for flush, she means like how far the stick out, being fluch has when you look at the side of the car from an extreme angle, the tires stick out as far as the flair of the fenders stick out filling them out better width wise. Also gives a car a wider wheel track stance if pushed out some. This can put added stress on the hubs though having them out too much.
hessemer69 on AIM
Old 02-09-2004, 01:36 AM
13lbs sounds nice but I couldn't deal with the poor ride.
Old 02-09-2004, 02:14 PM
Cali Guy
That's why "16 is a good way to go. You get thicker tires, but still a bigger than "15 look.
hessemer69 on AIM
Old 02-09-2004, 04:16 PM
chixSI's Avatar
Hey thanks SilverY2KCivic for all your help
Yeah i was going to get them in gunmetal. oh it's going to look so hot! i'm ordering them this friday since it's pay day at work, but when i'm all finished with my car, i'll make sure to post some pix. but thanks again for all your help, i now understand take it easy!
www.teckademics.com
www.dtmpower.net
www.motivonline.com
Old 02-09-2004, 04:38 PM
chixSI's Avatar
oh yeah one more thing about them...they are pretty light, the 16" are only 11.5 lbs. and they are also pretty expensive too...i'm paying $305 each without tires for the 16". but hey they are worth it.
www.teckademics.com
www.dtmpower.net
www.motivonline.com
Old 02-09-2004, 11:23 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I'm getting a set of 15s hopefully this year for autocrossing. 9lbs BLING!
But between 16s and 17s I would also go with 16s since they would ride better, not throw off your odometer and speedo as much and tires would be cheaper AND less rotational mass.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 02-10-2004, 02:16 AM
Cali Guy
Your welcome, anytime! I'm going to be getting myself some new wheels soon too, The set I have on my car right now will be my race only wheels, and then I'm planning to get a set of the same wheels I have now, but with a black face and polished lip.
hessemer69 on AIM
Old 06-21-2004, 09:48 AM
sfenton311's Avatar
sfenton311 sfenton311 is offline
Send a message via AIM to sfenton311 Send a message via MSN to sfenton311 Send a message via Yahoo to sfenton311
Im getting ready to order some SSR comps too. But was wondering about width on the 16s, is wider better? I can get a 16 x 7.5. Should I? What is the pros/cons.
Thanks.
To get what you do not have, you must do what you have not done.
- Unknown
Old 06-21-2004, 01:06 PM
Civic Mod
I ran 16x7.5" Kosei K1s and depending on which year Civic you have your inner wheel lip may hit the rear upper control arms. At least mine did until I filed some of it down. I had a 45mm offset.
I would play it safe and get 16x7" with 42-44mm offset.
Autocross Help Page
Buy my Civic parts!
Old 06-21-2004, 01:12 PM
sfenton311's Avatar
Here's the facts on the wheel:
Size Selected: 16x7
Recommended Tire Size: 205/45-16
Wheel Offset: +42mm
Can I bump up the sidewall to 50? or should I stay at 45? What is the pros/cons? I would assume a smoother ride with a 50...
- Unknown
What oil should i use??? MaxPowers_68 Grand Marquis 15 03-19-2004 11:13 AM
Poll- what color should I use?? sugarcaddy Car Modeling 12 03-11-2003 06:19 PM
What color should I use..... ruffman Car Modeling 1 09-21-2002 09:49 AM
what engine should i use? honda junkie01 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-15-2002 02:13 PM
what ECU should be used for the B16A engine? bamer02 Engineering/ Technical 1 03-29-2002 10:21 PM
