Old 06-04-2002, 07:37 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
IACV Problem?
welp i took the throttle body of my moms 97 civic dx with a d16y7 today to clean it up because she has had an unusualy high idle which was not correctable by adjusting the screw. i cleaned all the parts out with throttle body cleaner and assembled it all back together again and started the car and now the idle surges drops surges drops surges drops and so on. its hunting for an idle basically and cant find one. i am almost absolutly sure its the idle air control valve but wanted to see what other people thought before i bought a 200$ part. i have three sensors to guess and they are all expensive as hell, IACV, MAP sensor, and throttle position sensor. tell me what YOU think.
thanks for any help.
rick
Old 06-04-2002, 11:40 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
is the ecu throwing any codes? with those sensors theres usually a code for each of them individually... are all the vacuum hoses connected securely and in the right place, you never know, if you took any off you may have misplaced one and not noticed.
Old 06-05-2002, 12:57 AM
ric's Avatar
ric ric is offline
nope no codes, just a jumping idle. and believe it or not there are no vacuum lines the run into the dx throttle body. oh and its not the idle air control valve like i thought, that is actually integrated into the throttle body itself the valve im talking about is the rotory valve.
Old 06-05-2002, 03:31 AM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
usually the jumping rpms are associated with:
idle set to high (try readjusting the rpms)
vacuum leak. if one of the sensors were burned the idle should go reaaly low, almost to the point where the engine stalls.
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
HRV IACV problem la_do HRV 1 01-01-2013 09:22 PM
High Idle with New IACV - E150 XLT leroge Econoline 0 01-15-2011 05:21 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
IACV problem d_fl8ted1 Integra 5 04-18-2004 05:50 PM
IACV Problem ric '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 06-10-2002 11:12 PM
