Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-15-2004, 12:52 PM
d_fl8ted1 d_fl8ted1 is offline
IACV problem
can anyone tell me if you unhook the idle air contral valve something will go wrong, my integra is jumping around on idle and fluxuating, i unhooked the valve and it stopped... will it hurt to just leave it unhooked... please help
thank you
Old 04-15-2004, 01:31 PM
wickedplastikman wickedplastikman is offline
Re: IACV problem
leaving it unhooked will affect your cold starts. since you have it off, spray it really well with carbeurator cleaner. commonly, it gets clogged with god knows what. don't poke around in there because there is a screen filter in it to keep that buildup out of it.
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
Old 04-17-2004, 05:56 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
sounds like your iavc is no good. just go get a new one....autozone..i think it was $125 new. ebay $ 34.99 used but still good =) if it doesnt solve the problem, most likely it is though, then search for vacuum leaks.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 04-17-2004, 08:34 AM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: IACV problem
I have a friend selling on off a LS for $10 if you are interested. I will call him if you want it.
Old 04-18-2004, 03:40 AM
almxdupintegra almxdupintegra is offline
Re: IACV problem
Is it easy to disconnect? I have the same problem. Is there a step by step site I can look at.
Old 04-18-2004, 05:50 PM
it is easy to install all you have is two 10mm bolts i believe they were, and then two hoses and the wire connections, very simple
HRV IACV problem la_do HRV 1 01-01-2013 09:22 PM
High Idle with New IACV - E150 XLT leroge Econoline 0 01-15-2011 05:21 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
IACV Problem ric '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 06-10-2002 11:12 PM
IACV Problem? ric Engineering/ Technical 3 06-05-2002 03:31 AM
