Old 06-04-2002, 06:20 PM
Civic 1.6i VT Civic 1.6i VT is offline
VTEC Controller for EE9
I have sourced a Spoon VTEC Controller for a JDM EF8/EF9. It allows VTEC to cut in at 4800 rpm & redline 8900 rpm. I am told it plugs straight in using the supplied harness.
Does anyone know if I can simply plug it in to my EDM (EE9) Civic?
Will I need to change ECU etc???
Thanks.
Old 06-04-2002, 07:10 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Im sorry but if you buy it your wasting your money.
The Factory ECU will engage VTEC at 4,800rpm under full throttle anyway.
And a redline of 8,900rpm is useless unless you have some cams that will make power that high.
The factory cams stop making usefull power at about 8,200rpm which just happens to be when the limiter cuts in. (there is a good reason its there).
If you spend the money on a set of Civic or Integra Type-R cams then being able to rev to 8,900 would be usefull, and buying the spoon controller is a good idea.
It should fit striaght into your existing harness.
Vtec Controller For 04 Accord-help Needed 808accord9 Accord/TSX/Accord Hybrid 2 10-18-2004 04:09 PM
vtec controller for sale mjarrett Cars/Parts for Sale/Exchange 0 01-14-2004 08:39 AM
Vtec Controller?...why recomended for H22? integramus Engineering/ Technical 3 08-14-2002 12:42 PM
