Old 10-11-2004, 06:04 PM
808accord9 808accord9 is offline
Unhappy Vtec Controller For 04 Accord-help Needed
I recently bought an 04 ACCORD V6 6spd, and I did a K&N filter, Tanabe drop springs, 2 HKS Hi-power exhaust cans and custom 2.5 to 3.0 mandral piping. I wanted more power so I bought a VTEC controller and my friend and i have gotten all the wires but two. I got a diagram from HONDA and we can't find the wire to the THROTTLE POSITION SENOR and the RPM wire. The VTEC controller is pretty much just an expensive gauge. Can someone help me?
Old 10-11-2004, 06:26 PM
phantastic1 phantastic1 is offline
Re: Vtec Controller For 04 Accord-help Needed
don't know which wire you are looking for on the tps b/c it has 4....look behind the pcm...the 24 pin connector
-Sensor input (NC) is pin 14...a blue wire
-Reference Voltage (VCC1) is pin 6...a yellow/red wire
-Sensor Input (NM) is pin 8...a red wire
-Reference Voltage (VCC2) is pin 12...a yellow/blue wire
about the rpm....believe the rpm readings are from the cam position sensor...if so then
-CMP is pin 7 on the same 24 pin connector as the tps...a yellow wire.
hope that helps
Old 10-18-2004, 04:09 PM
I tired all the wires and for the throttle, the signal that i get is either at 100% or 0%. So basically I won't be able to tune my VTEC. Thanks for trying to help.
