Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 05-29-2002, 10:23 PM
stas528e stas528e is offline
Question mpg indicator under the tach not working
Where is the sensor for this vacuum gauge? My batteries in the SI board haven't been replaced for about 10 years, I looked at them about 2 years ago, the acid is coming out of them because they are so old and I think one of the connectors is broken. It was working fine until about two months ago, it started working periodically, whenever it wants to kick in. What's going on?
all good on the beema front
Old 06-22-2002, 06:48 PM
forum15 forum15 is offline
Send a message via AIM to forum15
I don't know how to fi x your gauge but I do know that the mpg gauges are notoriously wrong.
Old 08-03-2002, 05:50 PM
SimonP SimonP is offline
The MPG indicator doesn't work on vacuum. The ECU works it out from the speedo pulses, engine RPM and fuelling.
The SI batteries can fail short-circuit and kill the guzzle gauge.
Removing them and cleaning the gunge off the board may allow the guzzle gauge to work but i'm not sure if the SI will work correctly without them.
Replacement NiCad Cells are available from numerous sources, including model shops! (Tag-ended cells for making up custom battery packs!!)
Tach not working, Hard shifting, And oil in the plug wells beenthere98 Eclipse Problem Diagnosis 6 07-16-2008 11:27 PM
95 Transport - dim lights/no power/speedo and tach not working? 5spd GT Trans Sport 12 10-30-2007 01:34 AM
Tach not working? jmoo2416 924/944/968 7 07-01-2004 08:15 AM
speedo and tach not working walt0023 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 04-07-2003 07:01 PM
mpg indicator under the tach not working stas528e 5 Series 0 05-29-2002 10:27 PM
