Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 06-25-2004, 07:18 PM
jmoo2416 jmoo2416 is offline
Tach not working?
My Tach in my 1983 944 stopped working. Any suggestions?
Old 06-27-2004, 06:51 AM
83-944 83-944 is offline
Re: Tach not working?
Loose wire?
You'd have to pop the tach out and run a test light to the sending wire and +. That would tell you if the tach is dead. (the light should blink in time w/ engine RPM) Next would be the wires themselves. Test the light w/ a known +12 from the fuse panel.
Reply w/ results.
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
Old 06-27-2004, 07:50 AM
Tach not working
Thanks for the help! What is a +12 fuse? Is that the location of the fuse which controls the tach voltage? If not is there a fuse which controls the voltage to the Tach?
Old 06-28-2004, 07:19 AM
930guy 930guy is offline
though I'm not 100% sure I believe the tach signal comes off the coil and if this is true you will blow your test light out
Old 06-29-2004, 11:43 AM
The coil is only fed 12 volts from the DME. It is somewhat possible to get backfeed from the coil.
Either way, it's gonna tell you that the tach is getting signal.
Old 06-30-2004, 05:10 PM
It's fixed
RE: Tach not working: noted my MPH gauge also was not working. Both the tach and the mph gauge were not working. The cause was a loose wire. Both are fixed and back in operation thanks for the help.
Old 07-01-2004, 05:10 AM
Glad to be of help. Did you mean MPG gauge by chance?
Old 07-01-2004, 08:15 AM
Smile
Yes my mistake I ment the MPG gauge.
