Old 07-31-2001, 07:27 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
50 Ways to Scare People in a Computer Room
Some are good. Some - not so much. Enjoy
1.Log on, wait a sec, then get a frightened look on your face and scream "Oh my God! They've found me!" and bolt.
2.Laugh uncontrollably for about 3 minutes & then suddenly stop and look suspiciously at everyone who looks at you.
3.When your computer is turned off, complain to the monitor on duty that you can't get the damn thing to work. After he/she's turned it on, wait 5 minutes,turn it off again, & repeat the process for a good half hour.
4.Type frantically, often stopping to look at the person next to you evilly.
5.Before anyone else is in the lab, connect each computer to different screen than the one it's set up with.
6.Write a program that plays the "Smurfs" theme song and play it at the highest volume possible over & over again.
7.Work normally for a while. Suddenly look amazingly startled by something on the screen and crawl underneath the desk.
8.Ask the person next to you if they know how to tap into top-secret Pentagon files.
9.Use Interactive Send to make passes at people you don't know.
10.Make a small ritual sacrifice to the computer before you turn it on.
11.Bring a chainsaw, but don't use it. If anyone asks why you have it, say "Just in case..." mysteriously.
12.Type on VAX for a while. Suddenly start cursing for 3 minutes at everything bad about your life. Then stop and continue typing.
13.Enter the lab, undress, and start staring at other people as if they're crazy while typing.
14.Light candles in a pentagram around your terminal before starting.
15.Ask around for a spare disk. Offer $2. Keep asking until someone agrees. Then, pull a disk out of your fly and say "Oops,
I forgot."
16.Every time you press Return and there is processing time required, pray "Ohpleaseohpleaseohpleaseohplease," and scream "YES!" when it finishes.
17."DISK FIGHT!!!"
18.Start making out with the person at the terminal next to you (It helps if you know them, but this is also a great way to make new friends).
19.Put a straw in your mouth and put your hands in your pockets. Type by hitting the keys with the straw.
20.If you're sitting in a swivel chair, spin around singing "The Lion Sleeps Tonight" whenever there is processing time required.
21.Draw a picture of a woman (or man) on a piece of paper, tape it to your monitor. Try to seduce it. Act like it hates you and then complain loudly that women (men) are worthless.
22.Try to stick a Ninetendo cartridge into the 3.5" disc drive, when it doesn't work, get the supervisor.
23.When you are on an IBM, and when you turn it on, ask loudly where the smiling Apple face is when you turn on one of those.
24.Print out the complete works of Shakespeare, then when its all done (two days later) say that all you wanted was one line.
25.Sit and stare at the screen, biting your nails noisely. After doing this for a while, spit them out at the feet of the person next to you.
26.Stare at the screen, grind your teeth, stop, look at the person next to grinding. Repeat procedure, making sure you never provoke the person enough to let them blow up, as this releases tension, and it is far more effective to let them linger.
27.If you have long hair, take a typing break, look for split ends, cut them and deposit them on your neighbor's keyboard as you leave.
28.Put a large, gold-framed portrait of the British Royal Family on your desk and loudly proclaim that it inspires you.
29.Come to the lab wearing several layers of socks. Remove
shoes and place them of top of the monitor. Remove socks layer by layer and drape them around the monitor. Exclaim sudden haiku about the aesthetic beauty of cotton on plastic.
30.Take the keyboard and sit under the computer. Type up your paper like this. Then go to the lab supervisor and complain about the bad working conditions.
31.Laugh hysterically, shout "You will all perish in flames!!!" and continue working.
32.Bring some dry ice & make it look like your computer is smoking.
33.Assign a musical note to every key (ie. the Delete key is A Flat, the B key is F sharp, etc.). Whenever you hit a key, humits note loudly. Write an entire paper this way.
34.Attempt to eat your computer's mouse.
35.Borrow someone else's keyboard by reaching over, saying "Excuse me, mind if I borrow this for a sec?", unplugging the keyboard & taking it.
36.Bring in a bunch of magnets and have fun.
37.When doing calculations, pull out an abacus and say that sometimes the old ways are best.
38.Play Pong for hours on the most powerful computer in the lab.
39.Make a loud noise of hitting the same key over and over again until you see that your neighbor is noticing (You can hit the space bar so your file isn't affected). Then look at your neighbor's keyboard. Hit his/her delete key several times, erasing an entire word. While you do this, ask: "Does your delete key work?" Shake your head, and resume hitting the space bar on your keyboard. Keep doing this until you've deleted about a page of your neighbor's document. Then, suddenly exclaim: "Well, whaddy a know? I've been hitting the space bar this whole time. No wonder it wasn't deleting! Ha!" Print out your document and leave.
40.Remove your disk from the drive and hide it. Go to the lab monitor and complain that your computer ate your disk. (For special effects, put some Elmer's Glue on or around the disk drive.
Claim that the computer is drooling.)
41.Stare at the person's next to your's screen, look really puzzled, burst out laughing, and say "You did that?" loudly. Keep laughing, grab your stuff and leave, howling as you go.
42.Point at the screen. Chant in a made up language while making elaborate hand gestures for a minute or two. Press return or the mouse, then leap back and yell "COVEEEEERRRRRR!" peek up from under the table, walk back to the computer and say. "Oh, good. It worked this time," and calmly start to type again.
43.Keep looking at invisible bugs and trying to swat them.
44.See who's online. Send a total stranger a talk request. Talk to them like you've known them all your lives. Hangup before they geta chance to figure out you're a total stranger.
45.Bring an small tape player with a tape of really absurd sound effects. Pretend it's the computer and look really lost.
46.Pull out a pencil. Start writing on the screen. Complain that the lead doesn't work.
47.Come into the computer lab wearing several endangered species of flowers in your hair. Smile incessantly. Type a sentence, then laugh happily, exclaim "You''re such a marvel!!", and kiss the screen. Repeat this after every sentence. As your ecstasy mounts, also hug the keyboard. Finally, hug your neighbor, then the computer assistant, and walk out.
48.Run into the computer lab, shout "Armageddon is here!!!!!", then calmly sit down and begin to type.
49.Quietly walk into the computer lab with a Black and Decker chainsaw, rev that baby up, and then walk up to the nearest person and say "Give me that computer or you'll be feeding my pet crocodile for the next week".
50.Two words: Tesla Coil.
Resistance Is Futile (If < 1ohm)
Old 07-31-2001, 07:50 PM
kris's Avatar
kris kris is offline
Off playing with fire.
:hehehe: :hehe: LMAO, thats pretty good
Old 07-31-2001, 09:12 PM
primera man's Avatar
"P-Man"
hahahaha....now that was good
View All My Models Here.
Old 07-31-2001, 11:04 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
hehehheehe, Done both of those at school.
There all good for a laugh.
Old 08-01-2001, 07:19 AM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
These are good! I've done a few, though I won't say which.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 08-01-2001, 01:28 PM
Lizard King's Avatar
Lizard King Lizard King is offline
Haha Yeah, I've done a few of those before.
I get ideas for crazy stuff like this. One idea was to act nervously and stand up every time someone enters the room. Whenever someone gets up from their chair you could reach inside of you jacket, pretending you have a shoulder holster, but then relax and sit down again. I would like to see peoples reactions.
Or if you had some friends with your warped sense of humor you could get them to wear black suits and sunglasses and follow you around the streets. Whenever there is a loud noise they could jump on you as if they are bodyguards. Passing people would wonder if you're a VIP or something.
Old 08-01-2001, 04:04 PM
Porsche's Avatar
Porsche Porsche is offline
Pretty much amazing
Send a message via MSN to Porsche
Sounds like a Plan, thanks for the suggestions Yogs, My school's got 600 computers and plenty of time.
ec437 on grammar;
Originally Posted by ec437
I'd've
Originally Posted by 2strokebloke
Any car built by "Dr. Technology" is probably not worth $5000
Old 08-01-2001, 10:42 PM
YogsVR4's Avatar
Please be discreet so you can reuse the good ones
Old 08-02-2001, 01:10 AM
"P-Man"
Re: 50 Ways to Scare People in a Computer Room
I done this at work last night and they thought i was nuts !!!!
Everyone came rushing in and started looking at the screen and asking what's up.
I got a huge laugh from looking at them
Old 08-04-2001, 12:25 AM
gang$tarr's Avatar
gang$tarr gang$tarr is offline
ahahahhahahahahhaa, that's hilarious
i once had a disk fight at school, i found a stack of disks and juss start launching them at people, and using them as frisbee's, throwing them at my friends. in approx. 2 min the whole class was throwing disks all over the place.... then when the teacher came back i got bbbbbiiiiiggggg lecture about how i don't respect other peoples property and that i take computers for granted. hahah, she just feels bad cause every car in the students parking lot is better than hers! hehe
1992 323 Electrical/computer problem Lilautoworker 323/Protegé/Familia/Etude/Allegro 1 06-22-2010 05:22 AM
Computer software on my Z-3 scrambled - why? fabricatortim Z3 0 09-01-2009 07:21 PM
2000 Toyota Camry Rebuilt Transmission Computer Problem gujuchokra Camry/Camry Hybrid/Vista 5 08-20-2009 08:45 PM
What if People Bought Cars Like They Buy Computers igor@af COMPLETELY off-topic 15 01-05-2004 11:55 PM
Time to clean the computer room.... VideoNasty Car Modeling 12 04-09-2002 12:40 AM
