Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 05-31-2010, 12:05 PM
Lilautoworker Lilautoworker is offline
1992 323 Electrical/computer problem
We just got my car inspected on 5/29/10 and it passed and was working fine. Yesterday I went to start it and it wouldn't turn over, or anything. The lights don't work, nothing works. I did hear a kinda loudish clicking/ticking noise by the gear selector,(its the automatic SE version) Nothing Electrical works, any help? I don't think the battery is dead or anything like that. Do you think it might help if i get a video of it?
Old 06-22-2010, 05:22 AM
DoctorCrobe DoctorCrobe is offline
Re: 1992 323 Electrical/computer problem
well, let me ask a few questions to Clarify some things..
when you turn the key, you get no power to your dash? what about when you open the door, does your dome lights come on at all?
Have you checked to make sure your battery cables are tight on the battery? Batteries don't usually like cold weather, and it could be yours as been dying off for a while..
might also check to see if the cable came loose down on the starter, if you still have power, but the starter just clicks when the ignition is turned..
wal-mart's Tire & Lube express can test batteries, as well as any auto part store that does, it's usually free.. suggest pulling the battery and have it checked out. pay attention to the cranking or cold cranking amps, if they are way low.. then chances are the battery is toast..
if you get a new battery and everything seems fine, take it down and have them do an alternator test to make sure it's working correctly...
after you have done the basic checks that you can do yourself, and nothing is still working, double check all your fuses and make sure you didn't blow any, there should be some under the hood as well as in the vehicle on the driver side.. not to sure about the 323's..
hope some of this helps
Tags
323 , computer , electrical , mazda
