Old 05-21-2002, 11:35 PM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
axels for B16A into 90 DX HB?
My friend Bryan did a B16A swap into his 90 DX HB. Does anyone know what axels and joints you have to use. He was told that you have to use 86-89 Integra axels with 90-93 Integra joints. He also had to change the hub from 4 to 5 speed and he was also told that the CRX Si hubs would work because they were 5 speed to begin with and are pretty much the closest thing to the 4th gen HB. All replies are apperciated.
95 Integra GS-R
[email protected]
Old 05-22-2002, 07:23 AM
ricodemus ricodemus is offline
it depends on which intermediate shaft you get. With a 90-91 teg int. shaft, you need the 90-91 teg axles. But if you get a true SiR int. shaft, you use the combo like you mentioned earlier if you dont get SiR axles. more is explained here http://www.hasport.com/B16axles.htm.
I'm a lonely male who'll settle for any phony in a ponytail - MCPB
The b16 is in and running strong
putting 4.3 out of s-10 into hb 4x4 rongk General Discussion 1 08-16-2004 03:06 PM
axles for B18B into 88 HB.....86-89 or 90-93 teg axles? bambam89lx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 04-02-2004 12:02 PM
swapping 90 B18A1 into hb GScivic7 '88 - '91 Civic | CRX | Wagon | Shuttlee 4 07-12-2002 07:51 PM
Need help ! B16a into a 93 Civic essex Engineering/ Technical 10 03-23-2002 12:51 AM
b16a into 97 Civic DX... Cost? jeisai Engineering/ Technical 0 01-13-2002 05:31 AM
