Old 03-12-2002, 08:57 PM
essex essex is offline
Need help ! B16a into a 93 Civic
Hey everyone I got a question--Will the first gen (88-91) B16a bolt right into a 93 Civic? What would I have to get to make it all work ?Thanks for the info. :alien: :licker:
Old 03-13-2002, 12:08 AM
Scooter Bug's Avatar
Scooter Bug Scooter Bug is offline
Send a message via AIM to Scooter Bug Send a message via Yahoo to Scooter Bug
if i'm not mistaken i think it should mostly drop right in. you may want new mounts, computer, shift linkage, I'm not sure about axles, is the car EX?? if not you'll need the VTEC wiring harness.
Anyone else??
Becca
97 Civic EX
90 CRX DX
Old 03-13-2002, 01:07 AM
No unfortunantly it`s a DX...When I got it I wanted a really light car and it`s one of the lightest
Old 03-13-2002, 11:13 AM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Yes the motor will fit with these:
http://www.hasport.com/M92_CC.htm
It will end up costing the same if you get a B16a2 ... plus it will be much easier and the motor will be newer ... I'd go with the hydraulic tranny ...
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 03-16-2002, 04:45 AM
jOYRiDe jOYRiDe is offline
u cant retro fit an 88-91 engine into a 92-95 civic, it will be pointless because of the cable/hydraulic clutch difficulty
save up some more cash and get the EG series engine (front cut if possible)
Old 03-21-2002, 09:17 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
Doing that is not worth the time money or effort... First off you will need to get an adapter for the trannys because 1 is hydraulic and 1 is cable. you are going to have to do the basics motor mounts and all but you are going to have to get them anyways. Here is where its gets pretty... You are going to have to rewire the whole car. 88-91 is pre obd and the 92-93 is OBDI or OBDII. Not worth it. Just get the b16a2, you will end up spending less money and get that extra 10 HP.
Old 03-22-2002, 03:45 PM
extra 10 hp from a b16a2? i thought the b16a (JDM SiR) had 170 hp and the b16a2 (delsol?) had 160hp.... am i mistaken?
Old 03-22-2002, 10:20 PM
VTEC_boi's Avatar
VTEC_boi VTEC_boi is offline
Send a message via AIM to VTEC_boi
Ok..here goes:
1) Non-OBD motor into OBDI car. It can be done, but wiring is a bitch. It's also a bit on the illegal side.
2) Cable transmission into hydro car. HASport does make a cable conversion kit. But that's just extra parts.
3) Finally, the B16A (1st gen.) had only 158hp. The B16A found in the 92-00 SiR/SiRIIs had 168hp and the B16A2s found in del Sols and 99-00 Si Civics had 160hp.
Get it? Got it? Good.
"Son, your eyes look a little red there. You've been hittin the Vtec haven't you? Alright, stand on one foot, touch your nose and say 'Third Rocker Arm'".
Original PH Member (Reppin' for original PH'ers!)
www.lunspeed.com
www.jdmcivic.com
www.sweetcarz.com
Old 03-22-2002, 10:22 PM
Originally posted by VTEC_boi
Ok..here goes:
i was right :coolguy: well close enough
Old 03-23-2002, 12:36 AM
Well hell....for all that rouble I think I`ll just drop my turbo in the dx engine and milk it for all I can...I`m making about 115-120 now...and I don`t think it will be a problem to 35-50 more horses from the turbo ( garrett T-3 ).
Old 03-23-2002, 12:51 AM
u have a T3? dont u think its a bit large for a small engine?
