Old 03-29-2004, 11:22 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
axles for B18B into 88 HB.....86-89 or 90-93 teg axles?
I was searching around, and on the b16a.honda-perf.org website, Eric B. says that the 86-89 teg axles are better for a b-series swap than the 90-93 teg axles. I know that the 90-93 axles work, but aren't they just a little long? If i were to use the 86-89 axles, they would be the right length and I wouldn't have to remove the dust seal in the hub right? Would these be better or not...i'm wondering if anyone has any experience with this. On his website, he says these are better for a b16a into a crx but that should mean the same for a b18.
My car is an 88 dx HB converted to si w/mpfi and si tranny.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 03-29-2004, 12:09 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
i used 90 teg axles and intermediate shaft with my b18a swap.
As American As A Burrito!
USDM 4 life!
Old 03-30-2004, 07:32 PM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
Re: axles for B18B into 88 HB.....86-89 or 90-93 teg axles?
if it's 94+ and you have a cable tranny you'll probably need to change out the seal on the tranny to intermediate shaft and use a 94+ intermediate shaft.. you can use the 90-93 axle on the passenger side but you might have to combine a 94+ axle (the piece that fits on the intermediate shaft) and the rest of the axle of a 90-93 on the driver's side.. that's what i had to do.. also i had to swap my hubs with the 90-93 teg so the splines would be the same (i had a DX) they got bigger brakes as well
Old 04-02-2004, 06:00 AM
redmanjd redmanjd is offline
i used 91 axels on my b18b1
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 04-02-2004, 12:02 PM
bambam89lx's Avatar
AF - Advisor
actually I called marty at Raxles last week. He informed me that neither set is correct, while neither set is incorrect also. He told me what i already new which is that 90-93 axles are TOO long. They cause binding and suspension problems I.E. reduced suspesion travel. He said the 86-89 axles are the perfect length but the inner joints are too small and will pop out. He says the perfect axle for this swap (besides the raxles) would be 86-89 teg axles with 90-93 inners. There, problem solved. I've been on their site b4 but now i'm definitely gonna pick myself up some sticks from there instead of making my own.
