Old 05-17-2002, 11:43 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
Another Header Question.....
OK, I Had someone help me install me headers a couple of days ago (DC 2 pc Ceramic) and I noticed a wierd noise from the headers when driving, I then realized that it was a leak between the 1st and second section. I Tightened the 3 bolts and it fixed most of the problem, but I can still feel a small leak. What do I do to fix it? Should I take the bolts off and take the gaskets out, clean em, and put them back in?
Thanks for any advice!
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 05-18-2002, 12:08 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
make sure you installed all 3 bolts. DC is notorious for leaving out a bolt.
Old 05-18-2002, 12:22 AM
thewoahna's Avatar
All 3 bolts are in, I thought of that and checked, the one was really loose, but I tightened it up!
AOL IM: WoahNa316
Old 05-18-2002, 01:52 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
take it apart and make sure the gasket is sitting right between them, use a high temp epoxy if that doesnt help.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-22-2002, 10:58 PM
luti luti is offline
Send a message via AIM to luti
My DC 2 pc Ceramic 4-2-1 didnt not come with a gasket for the joint between the 2 pieces, only 2 rings that sit into recesses. Is that how yours was? I think I am having the same problem. How did you fix your problem?
T3/T04E turbocharged ricer.
Old 05-22-2002, 11:51 PM
thewoahna's Avatar
Yeah, thats what I ment, the rings, not the gaskets. I called DC Sports and they are sending me some new ones, I think that the ones I had were defective. The one ring is working fine, its the other one on the other (the 2 in 4-2-1) leaking. I hope that when I get the new ones and use some High Temp stuff like suggested, that will get rid of my rattleing noise also, something doesnt sound right around 2500-3500 RPM's, It almost sounds like one of the little rings is bouncing aorund in its groove. Hope this all makes sence.
AOL IM: WoahNa316
Another car stereo question Speculant Car Audio 11 08-18-2010 07:37 PM
yet another header post...please dont ignore though rs97eclipse1695 Engine, Transmission and Drivetrain 7 01-14-2006 03:05 PM
Another Header Question gftb5 Camaro Discussions 6 10-08-2005 06:35 PM
header question???!! pls help xodus917 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 01-18-2002 05:10 PM
Header Question nemesls_2000 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 01-17-2002 04:05 PM
