Old 05-13-2002, 05:57 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Question boost
How much boost can i safely run on a pretty much stock d16z6 motor?
Old 05-13-2002, 10:04 PM
Poweredbyhonda's Avatar
Poweredbyhonda Poweredbyhonda is offline
Send a message via AIM to Poweredbyhonda
I am going to swap a d16z6 in my 4th gen. soon too and turbo!
Ive been reading that if u go with the greddy kits with nothing else u can safely run around 8 psi, but u may need some fuel upgrades, ive found most of my info from this site
http://pub19.ezboard.com/fturbod16forumturbod16
Im CyberSupra on there!
See ya there
Kyle Cox
project eg hatch in progress
http://www.nsmotosports.cjb.com
:badass:
Old 05-14-2002, 07:47 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..it all depends on your fuel/ignition system upgrades...check this board out... http://pub19.ezboard.com/fturbod16forumturbod16
SOLD!
Old 05-14-2002, 11:06 AM
Rgacke's Avatar
Rgacke Rgacke is offline
turboD16 is a great place, I'm Cent. I'm currently gathering parts but I know majority of the money is going to the fuel system and electronic/guages/ect. Thats what determines how much you can boost...and how built your engine is.
"shut the door Joshua, and let death pass by..."
Old 05-14-2002, 08:51 PM
gunnmen01's Avatar
one step at a time
Well i was gonna use either accels or MSD to upgrade my ignition. Hadnt thought much on fuel upgrades yet, inline pump fuel rail and maybe bigger injectors? what else would i need?
Old 05-14-2002, 10:18 PM
91zc 91zc is offline
You are going to need to get a fuel computer(s-afc or equivalent) or a standalone unit like the hondata sytem if you are using a P28 ecu or the zdyne system if you are using an obd0 ecu. Your stock ecu is not going to be able to control the larger injectors..thus the need for the standalone or piggyback electronics.
I would say run about 8 psi to be safe and if you tuning is dead on maybe 10 psi.
91 civic 4dr
b16a
14.8@94
Old 05-14-2002, 10:24 PM
gunnmen01's Avatar
fuel control unit
fuel control unit like the one that comes with the greddy 92-95 turbo kit?
Old 05-16-2002, 01:23 PM
Rgacke's Avatar
doesn't the greddy come w/a FMU? if so thats not the best method, it works but w/negative side affects. the FMU is a boost dependant fuel pressure regulator, meaninging that is senses how much boost you have and then blocks off the fuel return line-keeping more fuel in the rail/line-forcing more fuel through the injectors. There is different pressure disk ratios that you can change but the one you get is 12:1 meaning for every psi of boost you have, theres gonna be 12 more psi in the fuel system.
ex;
5 (boost) X 12 (FMU)= 60 + 45 (normal psi @WOT)= 105 psi of fuel pressue when you have 40-45 stock.
stock injectore that flow a maximum of 240cc are gonna end up running them selves ragged and then quiting on ya.
Old 05-16-2002, 01:39 PM
marked001's Avatar
Moderadur
...the greddy kits dont come w/ fmu's anymore..they come w/the blue/black boxes that control fuel/timing...can only be used w/ OBD1/2 wiring though...
SOLD!
Old 05-16-2002, 05:29 PM
gunnmen01's Avatar
I see
Ok i understand that. who makes a good fuel management system ? And where can i go to do a lil research on what i want?
how to install a boost gauge and boost controller on an sr20det kraniun 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 7 06-26-2004 03:31 AM
Boost vs. Boost/VAC joemathews Off-Topic 13 05-14-2004 01:12 AM
boost controller, boost gauge, and fule pump RiceRocket18 Off-Topic 18 03-09-2004 09:41 AM
No Boost,,,,Shows Boost GSX Creep Off-Topic 0 02-19-2004 08:04 AM
Boost controller and Boost gauge chris26969 Engine, Transmission and Drivetrain 3 06-28-2003 12:24 PM
