Old 04-14-2004, 11:53 PM
joemathews's Avatar
joemathews joemathews is offline
Boost vs. Boost/VAC
Which one is better, straight up boost or a boost/vac gauge? I've been looking into gauges recently, and am just trying to narrow down the field.
1996 Eagle Talon
Old 04-15-2004, 12:58 AM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Re: Boost vs. Boost/VAC
Vac/Boost without a doubt
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 04-15-2004, 01:31 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
I don't think lunar would look bad... but note that you can replace the bulb on the Phantom series with any color you'd like in LED.. or you could stick to bulb. It's cheaper.
Old 04-15-2004, 04:18 AM
kjewer1 kjewer1 is offline
AF - Advisor
vac/boost is not as accurate as a boost only guage. I've seen several that were pretty far off. You dont need to see vac every day. I have a vac guage that I used to use to setup the carbs on my old american cars, they're real cheap at parts stores. If I'm curious what my vac is after a cam swap or if I think there is a problem, I just hook it up.
I've been running an autometer sport comp 0-35 psi guage for 4 years and its still dead on with all of the electric pressure trasducers the car has been hooked up to (dyno).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-15-2004, 12:26 PM
AmericanEagle's Avatar
AmericanEagle AmericanEagle is offline
Send a message via AIM to AmericanEagle
I just install a Stewart Warner 30hg to 40psi guage. Most guys in the import scene never heard of them. So i decided to try them out.
Considering that i should be getting 14 to 15 psi from my upgrades the guage was dead on.
I tapped into the line leading to the fuel pressure . Between the manifold solenoid if that makes any differance.
1997 Eagle Talon TSI AWD A/T "Never Lift To Shift"
Injen Filter - Forge Motorsport BOV - Magnecor 8mm Race wires - NGK BPR7ES - Apex'i N1 - Joe p MBC - Modified Dejon "L" Pipe
Old 04-15-2004, 08:49 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
nobodys given a reason yet why you need or dont need a vac gauge in a turbo
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-15-2004, 11:39 PM
JoeWagon's Avatar
Banned
A vac gauge is no more useful to a DSM than any other car. There's no answer why it's needed, other than it helps in the same situations it helps on a motorhome. The reason not to get one said by 95 GSXracer is the issue of accuracy.
Old 04-16-2004, 11:31 AM
well on a non turbo a vac gauge can be useful. its just a measure of how fast the engines sucking in air, but the only time it would have vacuam on a turbo would be if there was a problem with the turbo
-1stGenRocks-
Old 04-16-2004, 07:10 PM
JoeWagon's Avatar
Banned
Turbo motors have plenty of vacuum at idle. It STILL can diagnose problems the same. 17-22'' Hg if I remember correctly.
Old 04-17-2004, 12:37 AM
joemathews's Avatar
Here's another mildly related question: what compatability issues are there between turbo timers and the factory alarms? My 96 tsi awd has a factory alarm (haven't driven the car enough yet to know what exactly it does though lol), but I'm also shopping for TT's and wondering which ones will work okay or not. Ideas?
1996 Eagle Talon
Old 04-17-2004, 02:48 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
i know the Apexi TT will work just fine, i have heard Greddy does too... but i just installed a Apexi TT in a 2004 SRT-4 and it works fine with the factory alarm!!
Old 05-13-2004, 06:25 PM
joemathews's Avatar
I just hooked up my boost/vac gauge and the gauge is showing roughly 10-15 psi of vac at idle. I haven't driven the car yet with the gauge, but will later tonight unless someone tells me not to soon! Hopefully nothing is wrong...just wondering if showing significant amounts of vac is normal? (stock T25 btw in case you didn't know).
1996 Eagle Talon
Old 05-13-2004, 06:56 PM
Sounds about right, i idle steady at 15 to 16 Hg.
Make sure that you secure all your splices and connections.You can blow the lines off when you get on the gas hard. I used a combination of zip ties and electric tape to make sure every thing held tight.
Also, i have an apexi TT and it's worked fine for over a year now.
Old 05-14-2004, 01:12 AM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
i was just thinking about the lunar too.. still can't decide on either Lunar or Phantom. any suggestions?.. price wise the phantom is cheaper.
06 Charger SRT-8 black.
