Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 07-28-2001, 07:45 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Dyno Results! Dissapointing...or is it?
Here are my dyno results for the day. Todays best run in blue and last years in red. Added since last year...JWT cams and Hotshot header.
Notice the drop in low end torque! It pulls all the way to redline but that low end drop really gets me. The final result, 146hp is OK I guess, but as George would say, "that's just trivia." I really need a solution for my torque drop.
Old 07-28-2001, 07:48 PM
G-Forces's Avatar
Banned
Here's the chart comparing one of the first runs of the day (RED) with my best run (BLUE). I got the final result by playing with the timing. I don't know what the actual setting is but it's less than 19 and greater than 15. I was just using trial and error. At less than 15 I lost power along the whole band and after 19 the power line started to get really jagged (onset of detonation). I didn't have a timing light so I used the monkey method, this monkey doesn't recommend that method. :monkeypis
Old 07-28-2001, 08:50 PM
Kenny-G Kenny-G is offline
Send a message via ICQ to Kenny-G
I thought Jwt cam and hot shot head "should" improve low end torque ( according to ser net ) here are a few thing I think of...
what kind of exaust do you use? Piping too big for na?
Got tune up yet?
Got new wheels? They might be heavier than your old one?
Finally....dyno mechine accurate?
Old 07-28-2001, 09:42 PM
G-Forces's Avatar
Banned
Well maybe not 'should' but keeping it close to the same would be OK too.
It's custom 2.25" piping with a Dynomax Magnaflo. It shouldn't be too big unless the new resonator is cloging things up. But usually backpressure will help low to mid torque.
Got tune up yet?
With only 37K km I don't think this is an issue. I did pull the plugs and take a look. They all looked fine. Except for the #3 cylinder that had a little oil in it. I'll be keeping an eye on it to see if this was just a fluke or not. They tunnel to the plug hole was dry but the threads had oil on them.
No I made sure to put me stock wheels on. They even have the same rubber used for my last dyno run.
Same one I've used since the beginning. I'd hope it's accurate. BTW how can you tell if it is accurate? It's not like there is an SAE calibration car driving around.
Old 07-29-2001, 11:18 AM
You got Jwt ecu yet? that should help refine the power band.
Old 07-29-2001, 12:03 PM
G-Forces's Avatar
Banned
Ohh don't even start that with me!!!!
You know where I can get one for the 99 G20? :silly2: :silly2:
Old 07-29-2001, 07:19 PM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
haha...JWT ecu heheh..:finger:
cool charts Jason.....dotn know about your low end torque issue..but 146hp at the wheels is pretty nice improvement.
i have access to a dyno around here so after my swap gets done, i'll post my chart too heheh
Luke C.
GDA Power!
Old 07-29-2001, 07:21 PM
what...they don't make one yet? I thought our motor is the same as the 98 200sx ser?.....hmm...
Oh yeah even they make it , it is going to run you another 500 bills...
Hey if you are going to sell your header in the future, let me know...you know, I bet you will get it turbo charge or things like that.
Old 07-29-2001, 08:43 PM
G-Forces's Avatar
Banned
They don't make one for the 98 SE-R either.
Well soon after JWT makes the 99 ECU I'll be starting to collect parts for a turbo setup somewhat like this!
http://www.b15sentra.net/sema.htm
Oh yeah they fit a JWT ecu on there but apparently it took a lot of work to jury-rig it up.
Old 07-29-2001, 10:23 PM
kenchan's Avatar
kenchan kenchan is offline
146hp at the wheels is very impressive!!! :frog: great work.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 07-29-2001, 11:21 PM
slickkedar's Avatar
slickkedar slickkedar is offline
im confused..........JWT doesnt havea ecu out for us (P11 owners) ??
Old 07-29-2001, 11:23 PM
G22DET's Avatar
JWT does NOT have ecu for the G20...i dont think they have any ecus done for the OBD2 ecus....i "think"...
Luke C.
GDA Power!
Old 07-30-2001, 08:06 AM
G-Forces's Avatar
Banned
I'm pretty sure they make one for the P10 (91-96) G20's.
Old 07-30-2001, 10:08 AM
RCer's Avatar
RCer RCer is offline
Jason, how smooth is your engine after the cams? At idle position I mean.
Americo
2000 Primera.
Old 07-30-2001, 11:27 AM
G-Forces's Avatar
Banned
Barely noticable. I sounds a little like it could do for a tune up. Just a very slight lope.
My Dyno Results SiRII '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 05-19-2003 12:20 AM
Performance parts for the US Evo...and dyno results! VQuick Lancer 1 03-20-2003 04:01 PM
Dyno results Neil82 Engine 30 02-08-2002 02:16 PM
Dyno results of my 2k supercharged Maxima Y2KevSE Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 19 12-27-2001 03:02 PM
Hi all.....Perth Dyno results... Pva_Glue General Discussion 20 11-19-2001 09:40 AM
