Old 05-15-2003, 10:12 PM
SiRII's Avatar
SiRII SiRII is offline
My Dyno Results
The Dyno was taken when I had the V-AFC installed. I don't know if they tuned the cam gears or fuel pressure. I have not dynoed it after I installed the JDM Header. So, this was before the JDM Header. I'll post the actual sheet when i get it scanned.
(B16A SiRII)
DYNORUN.001 Max POWER=116.8 Max TORQUE=101.0
DYNORUN.004 Max POWER=154.3 Max TORQUE=109.0
DYNORUN.009 Max POWER=156.3 Max TORQUE=112.5
DYNORUN.001 Was On V6 Settings. NO V-Tec.
DYNORUN.004 Baseline vtec 4900
DYNORUN.009 Baseline vtec 5100
So, is this good or bad results. (156.3 HP w/ 112.5 TQ)
Mods are listed at My Engine Mods.
Old 05-15-2003, 10:16 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
Re: My Dyno Results
(B16A SiRII)
dunno if its a typo, but u jumped up about 38 hp from run 1-2? j/w wut happened there, cuz thats a HUGE jump. which mod's did u have then? cuz...thas about 20hp to the wheels over stock. not questioning IF those are ur numbers, jus wondering howu did it.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 05-15-2003, 10:19 PM
SiRII's Avatar
No Typo. I accidently reset the V-AFC to V6 settings and there was no V-Tec. But, the guys at the shop corrected it.
Old 05-15-2003, 10:24 PM
ok...so wut mod's did u have at the time?
2003 Infiniti G35
Old 05-15-2003, 10:27 PM
SiRII's Avatar
External Mods:
Apexi V-AFC Controller
B&M Fuel Pressure Regulator
Weapon R Dragon Air Intake
Skunk 2 ECU
Type R Shift Knob
AEM Short Shifter
Test Pipe
Tanabe Hyper Medallion Exhaust
STR Cam Gears
SRD Crank Pulley
Drivetrain Mods:
ACT Clutch (6 Puck)
8lb. Flywheel
i don't know if they messed with the Fuel Pressure or the Cam Gears.
Old 05-15-2003, 11:08 PM
External Mods:
Skunk 2 ECU
Test Pipe
STR Cam Gears
SRD Crank Pulley
ok...so those are ur mod's that give u some more power...im sorri, i forget, which b16 do u have? the a (j-spec) or a2/3. cuz if its the j-spec...completely understandable...bout 15hp over stock...
but IMO 25 is kinda outta reach for simple bolts...
2003 Infiniti G35
Old 05-16-2003, 12:41 AM
SiRII's Avatar
i have the J-Spec SiRII motor.
Old 05-16-2003, 05:34 AM
mattyoung33 mattyoung33 is offline
Send a message via AIM to mattyoung33
why is your max power 156.3 HP? I dont know anything about dyno so sorry if this is a dumb question... i thought then engine itself was 170HP?
'99 Honda Civic HX
-17" ASA rims with Khumo's
-Lowered about 2" w/ eibach sportline springs
-KYB AGX full-adjustable gas shocks
-Injen cold-air intake
-Thermal full-catback exhaust
-Mugen style front/rear lips, type-zero sideskirts
-Grillcraft upper black grill
-custom painted interior
-strut bar
-hyper white headlight bulbs/piaa signals
-new paint job including painted side trim
Old 05-16-2003, 06:16 AM
shepworldwide's Avatar
shepworldwide shepworldwide is offline
Re: My Dyno Results
i would say those are good results and you won't really see to much more hp in an all motor application.
my friend has a 2000 B16a2 with>>>>
JDM ITR tranny
CTR pistons
Spoon head gasket
ram air hooked to stock Si box
Spoon carbon intake elbow
paper filter
JDM header w/ top heat shield
test pipe
Apexi World Sport exh (painted flat black)
USDM P30 ECU
Skunk2 OBD2-OBD1 Harness
Hondata stage 4
Skunk2 cam gears
Skunk2 stage one cams
Portflow inner valve springs
ITR Outer valve springs
Exedy clutch
ITR flywheel
and his best is 166whp and 114 torque. he won't really see anymore power without the aid of FI.
HTH
:twoguns:"shepworldwide":twoguns:
96 integra for sale or trade
huge northest meet may 31st. come check it out.
Old 05-16-2003, 11:23 AM
esp's Avatar
esp esp is offline
Send a message via AIM to esp Send a message via MSN to esp Send a message via Yahoo to esp
the 170 hp is rated at the crank. basically what the motor puts out. on dynos it reads what power you are puting down at the wheels not the crank. usually there is anywhere from a 10-20% loss of power in the drivetrain.
ok my civic which is an ex puts out 127 hp right? while i only get 105 when it is dynoed completely stock. get it.
its ok many people get confused here. it happens
*RIP* Integr8 aka Ryan *RIP*
5/29/03
www.fotki.com/esp
THIS OG IS GONE retired for good. peace yall. create a crew for me
Old 05-16-2003, 01:41 PM
SiRII's Avatar
That's at the flywheel. Actual HP to the ground will be 20-30 hp less.
Old 05-16-2003, 03:13 PM
ACURAmail.com ACURAmail.com is offline
Banned
the result is pretty fast man
160hp on wheel!!
Old 05-17-2003, 12:27 PM
SiRII have you dont the 1/4 mile yet? Im interested in what your car runs
'99 Honda Civic HX
-strut bar
Old 05-17-2003, 01:58 PM
SiRII's Avatar
not yet
Old 05-19-2003, 12:20 AM
shooting for low-mid 14's? cuz that sounds about rite w/ ur power an weighing only 2100.
2003 Infiniti G35
