Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 05-13-2002, 11:52 AM
northwestrally northwestrally is offline
Blower Switch went bad ---- ideas?
Without warning, my blower switch started acting up yesterday.
On the first four settings (off,1,2,3) there is no blower at all, but as soon as I switch it to "4", the fan comes on FULL BLAST.
Both the A/C & heater still work fine when the switch is on "4", and none of this has ever been a problem before. No other electrical problems anywhere else on the car, either.
I checked the fuses (the two 15-amp fuses located in the dash [below the power window switch]). Both fuses were fine. I wonder if I need to dismantle the heater-A/C switch area.
Could this problem be related to the fact that the LIGHTS for the heater buttons don't illuminate on occasion?
BTW - my "check engine" light is now on, too (just like it did for a few days last year before turning itself back off). Related problems?
Any suggestions would be appreciated.
Regards, Don Swier
Old 05-13-2002, 09:25 PM
boingo82's Avatar
boingo82 boingo82 is offline
Can't polish a turd.
Welcome to the club. Nearly every Nissan Primera/Infiniti G20/Nissan Sentra will have this problem at some time or other. Lucky for us it is simple to fix. It is, however, completely unrelated to the check engine light. It is also completely unrelated to the intermittent lights on your blower switches. As I understand it, the contacts on these lights are small and get dirty over time. Don't worry too much about it.
Go to your local Nissan or Infiniti dealer - Nissan might be cheaper - and ask for a new Blower Motor Resistor. It will cost under $30, most likely under $20.
For further instructions, go to SE-R.net
Good luck,
Emily
Old 05-13-2002, 10:12 PM
Too cool !!! Thank you for the prompt answer(s)!!!! Wishin' now I had an FSM, too!
I managed to get my commodious cranium under the glove box to get a look at the blower motor.
Once I located the blower motor, I wasn't sure if the resistor is the doohicky up near where the dash meets the floorboard OR if it's the thingy mounted under the dash nearer to the passenger seat. Do you have that info, too?
Your help is much appreciated!
-Regards, Don Swier
Old 05-13-2002, 11:15 PM
boingo82's Avatar
Well, it was a year and a half ago when I replaced mine, so I don't remember too well. I do know it was a little square dealie about 1.5"x 1.5" and flat. Also, you do need a screwdriver to get it out. It has contacts on it - those are the metal strips like on a nintendo game. Hope that helps.
Emily
Old 05-24-2002, 02:09 AM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
The blower resistor is located behind the glove box. It's actually against the lower portion of the firewall. The resistor is a board with contacts that simply fit male to female. It does look like a Nintendo cartridge only not as big and the contacts are exposed.
nightmaR3Z
06 escape blower fan switch milo42gpw Escape | Maverick | Escape Hybrid 1 03-26-2009 06:38 PM
No rear defrost or lights for the temp switch,blower switch,location switch? Brian03ZX2 ZX2 2 01-08-2005 12:14 AM
?really good idea for drift car/really bad idea? gigglesnirt Drifting 21 12-28-2004 12:06 AM
Used parts... good idea? bad idea? ProbeKiller 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 6 11-04-2004 03:49 PM
a/c blower switch or blower motor? Aggrev8ed GTP Ownr Grand Prix 5 06-28-2004 10:35 PM
