Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 05-07-2002, 06:14 PM
Jdub07 Jdub07 is offline
No broncos
I guess no one owns a ford bronco these days?
86 Hatchback DX
Strait Pipe
Flipped Lid
240 Watt Boss CD
Two 12" Rockford Fostgate Subs
1000 Watt Rockford Fostgate Amp
BullDog Alarm
Hood Locks
Yakima Roof Rack
Old 05-11-2002, 05:49 PM
bbkeagle bbkeagle is offline
Send a message via AIM to bbkeagle
Angry bronco not running need help
my ford bronco II won't run i am at a loss I have tried everything i can think of does anyone have any thoughts on this problem::
i have changed the fuel pump both in the tank and the high pressure pump in the line new fuel filter new fuel pressure regulator and new injectors i am at the end of my rope help if you can
Old 05-13-2002, 04:54 PM
broncoman broncoman is offline
What are the symptoms? Did it run and then die all of a sudden? Will it turn over but not start or just not turn over at all? Is the fuel pump soming on when you p-ut the key in the on position? You should hear the pump whir or rattle a little in the tank when you put turn the key on. How was it running before it died? Narrow it down for me and I might be able to help.
Old 05-14-2002, 05:49 PM
bronco II
it quit running because it had bad gas i think i bought it from a high school auto shop. they cleaned out the tank and put new filters on it but it would not start so i checked the fuel pump and it was bad so i replaced it and then i replaced the high pressure pump and the regulator and i also put new injectors in it and it still won't start it will turn over but it wont run unless you spray starter fluid in it but it wont stay running. it has good compression and good fuel pressure
Old 05-14-2002, 06:31 PM
Have you checked to see if the injectors are actually getting an electrical signal? Just hook up a test light to one of the plugs to the injectors and then crank it to see if they are. If not then they're not getting the signal from the computer to open. That's the first thing that comes to mind. Check that out and let me know. Since it fires with starter fluid, that means that there is spark, but it's still not getting fuel.
Old 05-15-2002, 01:13 PM
there getting fire all the time and there not pulsating im in the middle of putting a stater in the distrobitor and also replacing the mod.
Old 05-15-2002, 02:20 PM
I haven't had a little bronco and I usually stick to carburetion to avoid just the problem you're having, so what part of the computer or which solenoid or module controls the injector pulse? Is that the "mod" you're talking about, the ignition module? That would sound like a good place to start if the injectors are open constantly. Are all of them open constantly or is there maybe a short in the harness to the injectors that is sending all the juice to just one or two? Just trying to throw some ideas out there. I would definitely take a close look at the wiring from the computer or ignition module real carefully to make sure that it's in good condition and not shorting anywhere. Good luck and keep posting where you are on fixing it. Later.....
Old 09-22-2002, 05:52 PM
nstag8 nstag8 is offline
Cool I own one
I own a 78 bronco.It has a 5"Skyjacker lift,and rides on 35"tires.My wife has a66 mustang coupe.
Old 12-21-2002, 11:20 PM
75stroppe 75stroppe is offline
Does an early bronco count
75 Ford Baja Bronco By Bill Stroppe
Old 12-21-2002, 11:26 PM
:flash: Nice Ride!:flash:
Old 12-22-2002, 01:17 PM
Thanks a lot that pic was taken in San Jose California right before I drove it back to Chicago. Took me Four days with 4.11 gears and no overdrive.
Old 06-13-2005, 02:57 AM
Ree86bronco302 Ree86bronco302 is offline
I have an 86 bronco with a 302 efi and dual exhaust.Sony cdx-m630 with 2 12" subs. It is still a work in progress
Old 06-13-2005, 06:34 AM
dirty dan dirty dan is offline
Re: No broncos
Sharp!
My son and I are starting to put back together a '71. We're have ing a blast.
89 ford bronco 2 electric windows bigd428 Bronco 0 09-13-2010 09:25 PM
89 ford bronco 2 brake problem bigd428 Bronco 0 09-13-2010 09:14 PM
96 Bronco Fuel Tank Sending unit. mareco32 Bronco 1 09-06-2009 08:02 PM
are there any models of an '83-'92 Ranger, Bronco II, or Bronco? CrazyModGSR Car Modeling 14 01-07-2005 03:09 PM
Bronco 92 idle problem saul Commercial Trucks 3 03-09-2004 09:00 PM
