Old 05-02-2002, 12:03 AM
CRXkid CRXkid is offline
Send a message via Yahoo to CRXkid
H22A or B16A
I know about all your opinions and all, but my question is, what needs to be done to install a B16a, and what needs to be done to install a H22A. Both into a CRX. By this i mean mounting the engine, suspension, etc. Thanks in advance.
Old 05-02-2002, 01:25 AM
bc4g bc4g is offline
What needs to be done is there going to both need complete wiring changes. Place Racing and HAS sport make the special motor mount kits for the B16a. This is a much more common swap. With both motors you will have to wire in the VTEC. Now for the H22A there is no mount kit that I have seen yet you will have to beef up the front suspention a little youre going to have clearance problems and if you havent went to the hybrid honda web site and every where else on the web they warn against it for all the hassle you will have go with the GSR motor you'll spend less in the long run maybe and there are very few H22A that are faster than GSR 's If H22A swap was that good every one would do it.
Thanks
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 05-02-2002, 01:45 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
h22 is the hardest to do b/c it's the biggest engine and the reason you dont hear about it that often is because it's so exspensive but i would bet it coudl tear a gsr apart in a straight line but i hear it handles poorl but i bet you could minamize that with a really nice suspension
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 05-02-2002, 06:00 AM
civic1991 civic1991 is offline
Send a message via AIM to civic1991
Post
I found this on the hybrid board a few weeks ago
H22A (Prelude VTEC) in any Civic/CRX/Integra
The H22A engine leans in the wrong direction
Civic engines have blocks that lean forward while the H22A block leans backwards, towards the firewall. Even though custom fabrication will mount engine, it's still not suitable for this chassis.
Fabrication issues
Custom fabrication is required to get the H22 engine to fit. The stock motor mounts have to be removed and new mounts relocated, making this an expensive job. Modern day cars are designed from the ground up as an integrated structure, and this includes the engine. Moving mounts around causes the structural characteristics to change. Furthermore, it also increases the chance of a screwup happening.
Chronic understeer
The heavy load up front will cause tons of understeer. Furthermore, the added power up front will cause the front end to lose traction too easily. What you have is a car that goes fast, only in a straight line.
:apoke:
**DO YOU RACE OR JUST RICE**
What do those Altazzas add, like 15Hp? HAHAHAHAHAHA!!!!!!!!!!!
Old 05-02-2002, 04:31 PM
Phatwhippin_CRX Phatwhippin_CRX is offline
Send a message via ICQ to Phatwhippin_CRX Send a message via AIM to Phatwhippin_CRX Send a message via Yahoo to Phatwhippin_CRX
I've got a B16 swap write-up on my site......
www.phatwhippinCRX.20m.com
As far as the H22 goes, unless it's a TRACK-ONLY car, I would stay away from it.
As a matter of fact, if you want H22a power, but want a car that can actually turn, check out www.crvtec.com
H22 power from a B block...... the only thing is, its MAD expensive to do RIGHT. And if you're not gonna do it right, don't do it at all.......
1989 DOHC VTEC CRX Si
C'mon, it's only a Honduh...can't be fast!
I AM the Anti-Rice!
Swap info, Turbo tech, and naked chicks!
Old 05-04-2002, 03:40 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
STAY AWAY FROM H22 IN A CRX OR 4TH GEN CIV!!!!
You have to make ALOT of cutting under the hood to make it fit -- it WILL fit, but ANY accident you get into will rip your car apart like it was made of paper mache... not to mention the motor is so heavy compared to the rest of the car you will be plaqued with UNCORRECTABLE oversteer....
AF's Official Asshole
RIP AUNIE
Old 06-28-2002, 10:21 PM
nicsviper95 nicsviper95 is offline
There is a mounting kit i have found
I did find a mounting kit for an H22A engine in a 88-91 CRX at http://www.infinitemotorsports.net/PRI.0.html but you have to go down and look at them i think it is the 6th catagory down says 88-91 CRX/Civic w ACCORD or Prelude F22/H22/H23 so it's right there if you do want to find the mount kit ok thanks c~Ya.
What needs to be done to an H22a internally to make it boost safely? preludeguy017 JDM Motor & Parts info/chat 1 06-02-2010 01:28 AM
H22A or B16a SirII???? vonoven1 Engineering/ Technical 3 04-19-2003 04:05 PM
h22a vtec, b16a, or b18c for 94 hatch. robutek '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 03-15-2003 02:40 AM
h22a vs b16a blueturtle '88 - '91 Civic | CRX | Wagon | Shuttlee 34 02-18-2003 01:23 PM
b16a vs. h22a matraca280_112 Engineering/ Technical 13 11-23-2002 04:11 PM
