View Poll Results: which one do you think has morw power?
b16a 3 25.00%
h22a 9 75.00%
Voters: 12. You may not vote on this poll
Old 11-03-2002, 06:19 PM
matraca280_112 matraca280_112 is offline
Send a message via AIM to matraca280_112
Smile b16a vs. h22a
i want to know which one has more power? hp i just want to know. I am looking to buy a power plant but i want to know the on to buy. Mouny is not a problem for me.
Old 11-04-2002, 01:44 AM
justanothermike's Avatar
justanothermike justanothermike is offline
Send a message via AIM to justanothermike Send a message via Yahoo to justanothermike
H22 has 160lb/ft of torque vs the b16s 111. the H22 will eat the b16 alive
Old 11-05-2002, 05:00 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
B16A= 160 hp w/ 111 ft/ lbs. of torque
H22A= 195-200 hp w/ 160ft/lbs. of torque
the question is- what car are you planning to put this motor in?
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 11-05-2002, 09:11 PM
i was thinking of putting it in 94 integra. but is the h22a is so good then why dont more people use them in a swap. i want to make my car the best handling fwd car in my area.
Old 11-05-2002, 09:28 PM
delsolsi delsolsi is offline
The H22a is not a direct bolt in. Also if your wanting a good handleing car you don't want the H22a because it is very heavy and will screw up your weight balance which on a front engine front wheel drive car already is far from ideal.
Old 11-06-2002, 01:07 AM
think think is offline
Yup... Also, good luck in getting the engine to fit. Its going to be a tight squeeze, and your gonna have to re-do the mounts and everything. Probally not the easiest swap you could have picked.
Why dont you throw a b20 in it and put the b16 or b18 head on it?
"The More You Know, The More You Know You Don't Know Shit."
-MF DOOM
Old 11-06-2002, 07:27 PM
ok.... then if i go and put a b engien in it. then which one.there are like 5-6 of them. right? i want good power and wight to.
Old 11-07-2002, 04:23 PM
diegoaccord's Avatar
diegoaccord diegoaccord is offline
A B20A5!!!! with that stroke, and a VTEC head, shit man, your torque......... Nah a VTEC B20A5 has been done, but power was less than stock B16A. Do not do a CRVTEC or LSVTEC or oldLudeVTEC, just get B18C.
My cars:
Civic coupe EJ1. B16A, EG6 cluster. Wrecked/parting.
CRX DX ED8. DOHC ZC, I/H/E.
EJ1 Civic Si . Screw Hatchbacks. Coupes just look better. Period...
Old 11-07-2002, 06:44 PM
The-Pro The-Pro is offline
I have read that another problem with the H22 is they tilt back and to the left when you rev. The b series tilts forward and to the right. When I read this I thought "So." And it ends up that this screws with the cross-member and other mounts in your car, which are all made to take a forward tilt.
The site said H22 belongs only in a Prelude. And I'm going to catch a lot of flak for it because I lost the site I found that information on.
1995 Integra LS w/GS-R engine and ITR tranny
1997 GMC Yukon 4dr 4x4 to tow the integra from show to show
Old 11-08-2002, 01:45 PM
Fishcat37's Avatar
The B20A5 is from the 91 and older Prelude. I believe that it mounts up differently than all other B series engines, thus it would not be a straight drop in.
Appearance Mods:
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-MSD SCI-L ignition
Interior Mod
Former Cars
'94 Integra GS-R
'96 Camaro
Old 11-08-2002, 07:17 PM
Duatone Duatone is offline
ok, you want a good motor, screw the h22, like it was said, your going to screw up your good handling factor, either do the ls motor, and toss in a GSR crank, and youve got constant hp gain across the rpm band, and it has more tork than either of the b-series and will smoke them, not to mention the real specs for the B16 is the b16A2 JDM is 170 to the crank or flywheel, and the usdm B16A2 is only 160 the the crank/flywheel. though heres a good comparison for you, even thouhg people say not to do the B20 frank conv. we've raced a gutted crx with a B16A2 (170) with intake/header/exhauast/v-tec controller VS a 96 teg with a B20 frank. and i tell you this crx is fast!, but it got worked by the teg by a couple car lengths. though if you want to go all out go for the B18C5, no probs with that one here....
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 11-19-2002, 01:22 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Yea if money is no object go with the b18c5 or b16b forget the h22 unless on top of the motor you want to spend a ton on suspension to counter the weight issue.
Old 11-19-2002, 01:33 AM
Also you said you were thinking about dropping it into an integra why?Get yerself a 5th gen civic hatch or if you want to be really silly go check out www.plmini.com and do that.
Old 11-23-2002, 04:11 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Ok well theres a couple of ppl on www.civichatchback.com that has the h22 swap done to a hatchie! Thats all bullshit myth about handeling. Yes you'll lose SOME but not alot! I'd rather go with h22. They make mount kits for them. I believe HCP has the kits out for your integra. You'll need axles from www.raxles.com. Theres alot of shit you need but i can't think on top of my head rite now. If you're goin with b-series what do u want to do? Go all motor or go turbo? If turbo go str8 b20 or ls motor. If all motor go with gsr? I have a b16 in my rex rite now and i do love it but i want more torque. So i'm gonna do it the cheapest way. I'm gonna get me a type r block and mate it with my b16 head.
b16a vs. ZC vs. Sohc Vtec? QuickSilverEF9 '88 - '91 Civic | CRX | Wagon | Shuttlee 68 04-03-2006 02:58 AM
F20B vs. H22a friday86 Accord/TSX/Accord Hybrid 2 10-20-2004 09:14 AM
H22 vs H22a? euroAccorDeuro Accord/TSX/Accord Hybrid 11 08-28-2003 08:33 PM
b18c civic vs h22a prelude YOUNGSTER Street Racing 2 07-14-2003 06:53 PM
Turbo B16a VS Stroked B16a EF9JDM '88 - '91 Civic | CRX | Wagon | Shuttlee 28 09-03-2002 06:15 PM
