Old 05-01-2002, 12:24 AM
strodda strodda is offline
hard cold start
i have a 91 accord lx, i already posted on an accord specific forum, but i want everyones input.
when i start my car for the first time in the mornings, the engine turns over 4 or 5 times before it starts, but throughout the rest of the day its fine. has anyone else had that problem? and what did you do to fix it?
thanx
Old 05-01-2002, 01:56 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
My guess is that it might be your battery or alternator dying and not giving enough juice to the starter.
just a shot in a dark
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 05-01-2002, 02:47 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yea the starter is not getting proper power from the system, first check to see if the connections going to the starter are loose, then suspect alternator and battery for low life.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-01-2002, 03:11 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
If the engine is turning over at the normal rate, then it's not the starter...
I'd suspect a fuel delivery problem of some sort, but I wouldn't have a great suggestion for how you could track it down.
You might try the following the next time you do a morning start - turn the key to the "on" position, and let the car sit for a couple seconds before you try to start it.
Another thing that might work - "goose" the starter once for a really short time, then wait two secs and crank normally.
On the '97 civic that I used to have, it'd be slow to start whenever the gas tank was low. I never crank an engine continuously for more than 3 seconds (habit from having a jeep with regular starter/battery problems), so "slow starting" usually meant that it wouldn't start at all on my first try, and would start immediately on my second attempt.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 05-01-2002, 03:44 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
check your fuel pump relay
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 05-01-2002, 06:49 PM
i tried another little experiment, and i know it has nothing to do with a cold or hot start. i started the engine(turned about 5 times, then started) then turned it off right away. came back 10min later, and it started right away. im going to to get my battery tested, and i got a fuel injection cleaner, so im gonna try both of those.
im kind of hoping its just a bad battery(since i killed it about a week ago), and its just not keeping the charge well overnight.
Old 05-01-2002, 09:21 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
it's not your battery.
gathering from your little "experiment", the "problem" is that overnight, or any extended period, the gasoline slowly creeps out of the fuel lines and back into the tank. on the first start of the day, you're the type that just starts cranking the motor instead of turning the key to "on" and waiting a couple seconds for the fuel system to pressurise for a proper start.
read your owners manual.
Old 05-01-2002, 09:27 PM
it probably is your battery if you killed it.
But get ther B&M Fuel press gauge and put it on. See what it reads before starting, should be in the high 30 or low 40s
Old 05-02-2002, 03:53 PM
crxlvr's Avatar
PS - fuel injector cleaner is usless, it does nothing for your car that the gas you put in it doesnt do already.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-02-2002, 06:13 PM
Tofuboy's Avatar
When you turn the key to the "ON" position and not turn to the "crank" position in about 2 seconds the ECU will shut off the power to the fuel pump right away, so there will not be much of a difference on that.
95 Civic EX
83 Toyota Starlet
Old 05-02-2002, 06:59 PM
SleeperTeg's Avatar
SleeperTeg SleeperTeg is offline
actually it will prime your fuel system. the ECU shuts the fuel pump relay off after two seconds to prevent pressure buildup and backpressure on the pump and other fuel system parts. just enough to get the fuel system primed and under pressure.
Gretchen
Off Topic Morning Crew
Old 05-02-2002, 07:34 PM
ok thanks, ill try that.
and drift... my bad, i dont know where the hell i put the manual. im always losing shit.
ive never "primed" my fuel systems before start, and this problem has just gotten worse recently. is there some part in the fuel system that i should look into replacing?
and also, when i first start it, by the 3rd of 4th turn it does slow down. is that normal, or do i have a bad starter/alternator/etc??? i also read that my car should have a 550cca battery, mine is only 530 and i have a 2amp system. i already plan on getting a new battery, but is the extra drain adding to the problem?
Old 05-02-2002, 08:12 PM
Tofuboy's Avatar
If your engine slows down during cranking, then your battery is not providing enough ampage. If you have a mulitmeter, have someone check the voltage on the battery while you are cranking the engine, it should not drop below 9.6 volt. Since you can still start the engine I assume the battery is ok.
I still suspect the fuel pump relay though, but it's not a big problem, due to the oil pressure switch will over ride the fuel pump relay and provide the fuel pump power (fail safe). You will just have a hard start that's all, nothing bigge.
95 Civic EX
83 Toyota Starlet
Old 05-03-2002, 11:49 PM
ok, well i turned it to the "on" position before starting it, and that did nothing. i tried starting it one morning while it was hooked up to my moms car battery. but i dont know if that would have made a difference since her battery is only 230cca. although after it turned 3times, i stoppped it since it hadnt started. then turned it again, and it started on the first turn
if the problem is that fuel drains out of the line, is there something i should replace? is it the fuel pump that Tofuboy was talking about??
Old 05-04-2002, 05:26 PM
Tofuboy's Avatar
This is the 4th time I am saying the same thing but NOOO you never care what a tune up tech had to say.
All I am telling you is to check is your "Fuel Pump Relay" not the fuel pump, please check back what I had last posted.
95 Civic EX
83 Toyota Starlet
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
hard to start when cold 88alldae Caprice 2 08-03-2009 09:16 PM
96 Grand Am SE 2.4L Hard Starting Period Gman2007 Grand AM 2 04-13-2009 05:44 PM
hard cold starting silverado! RayJ C/K 1 10-27-2003 04:22 AM
Hard Cold Starts on '89 3.8L O.P Bonneville 6 09-12-2003 11:49 AM
