Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-05-2003, 06:42 PM
O.P O.P is offline
Hard Cold Starts on '89 3.8L
My bonneville has a real hard time starting when its cold. It kinda coughs and wants to start, it takes a few of these coughs before it fires up. Then once it briefly starts, it dies. As I attempt to start it again it might cough a little then run a little longer. Finally by about the 3rd or 4th time it gets better. Once it is warmed up it runs great and starts great, but after sitting a few hours, its is the same cycle. I've replaced O2 sensor, camshaft pos. sensor, TPS, Sparkplugs, wires, fuel pump, fuel filter. I have also let the car sit overnight and check the fuel rail the next morning and it seems to maintain sufficient pressure when i release the fuel valve. Any ideas?
OP
Old 09-06-2003, 01:40 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
The is an old tech bulletin on cold start stalls with these engines.
Most likely cause is a faulty IAC valve, If I remember right the part number for the new valve is a 17112650
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-06-2003, 08:45 AM
O.P O.P is offline
Where is the IAC valve located? Is there a way to test it and can you tell me where I can find the old tech bulletin dealing with the same problem.
OP
Old 09-06-2003, 10:24 AM
GMMerlin's Avatar
I know stuff
The bulletin # is 93-t-04
The IAC valve is located on the throttle body. It is round with 2 screws holding it to the throttle body and has a 4 wire connector.
The best test for that problem is to scan IAC counts with a scan tool...the counts will be different each time you start and let the car idle.
GM WCT
PM Me for details
Old 09-10-2003, 02:11 PM
O.P O.P is offline
Wow! I'm impressed. This car has given me hell for the last two years with the same problem. I have done all sorts of things to it EXCEPT for the IAC. Well, I must say that you are on the right track GMMerlin. I pulled of the IAC and it was stuck closed with ignition on and off. I cleaned it with carb cleaner and it began to move in and out. The car starts a hell of a lot better, it will start immediately, but it still turns off when i gas it. It does this twice before it stays on. It is giving me a service engine code 14 (CTS). I have replaced the CTS twice and the thing that i have noticed is that the car will fire up right away after i replace the CTS, but then the service engine light comes on and it continues with the same difficult starting problem. Am i burning out the CTS or is there a reset (I unplugged + batt for 10 min). Nonetheless, it does start better, but i want it perfect.
OP
Old 09-11-2003, 06:09 AM
GMMerlin's Avatar
I know stuff
the problem may not be the coolant sensor, but the wiring or ecm.
The coolant sensor is a 2 wire sensor..if memory serves me right, the wires should be yellow and black.
Check the service number on your ECM..if it is a 1228253 (or the last 3 digits are 253) replace it (perferably with a GM part). We had a lot of problems with that part number ECM and GM did an excellent job with coming up with a remanufactored one to replace it. (I dont trust aftermarket ECM's)
GM WCT
PM Me for details
Old 09-12-2003, 11:49 AM
O.P O.P is offline
The ECM has already been replaced. The Temp sending unit is a 2 wire and the CTS is a single wire. Both of these have been replaced. How many volts or ohms should be in the CTS wire?
OP
Air bag code 44, Windstar 96, 3.8l kafkacell Windstar 0 09-07-2010 07:56 AM
2000 SEL 3.8l Battery Cable Hot !! Nox Windstar 2 06-12-2010 12:06 AM
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
95 Mustang 3.8L-trouble starting... DDP87 Mustang Problem Diagnosis 3 09-27-2009 08:47 AM
hard to start when cold 88alldae Caprice 2 08-03-2009 09:16 PM
