Old 10-27-2003, 04:05 AM
RayJ RayJ is offline
Unhappy hard cold starting silverado!
I have a 2000 silverado 5.3. The problem is that when it gets cold below 32 degrees it becomes very hard to start. Cranks for quite a while before it finally turns over. Only on the coldest day. If I drive on those days and start it every 4 hours or so its fine. If I leave it about 8 hrs. I am going to have a problem.
Old 10-27-2003, 04:22 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: hard cold starting silverado!
Numerous things can cause a hard start condition.
First, what grade of fuel are you using? Any thing more than 87 octane can cause difficulty starting due to the faster evaporation rate of the higher octane.
Second, There have been numerous hard start problems caused by loss of fuel pressure. Fuel pressure regulators seem to be the biggest culprit.
remove the vacum line to the regulator and see if there is any evidence of fuel in the vacum line.
Also if you have access to a fuel pressure gauge, you can check the fuel pressure and if there is any bleed down.
Third, throttle bodys on those trucks have been know to cause low idle, stall and difficult starts from a build-up on the bore and blade...a good cleaning of the throttle body will help that situation.
Last, The possibility of a schewed sensor reading that is temperature sensitive could also be an issue...you will need a scan tool for that.
Hopefully this will lead you in the right direction.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
hard to start when cold 88alldae Caprice 2 08-03-2009 09:16 PM
96 Grand Am SE 2.4L Hard Starting Period Gman2007 Grand AM 2 04-13-2009 05:44 PM
Hard Cold Starts on '89 3.8L O.P Bonneville 6 09-12-2003 11:49 AM
hard cold start strodda Engineering/ Technical 14 05-04-2002 05:26 PM
